Topic: LED Scene selection? (Read 840 times) previous topic - next topic
Nancenificent
Code: [Select]
int R = 2;
int I = 3;
int C = 4;
int K = 5;
int Y = 6;
int D = 7;
int A = 8;
int L = 9;
int E = 10;
const int select = 12;
const int maxScene = 3;
int scene = 0;
  pinMode(select, INPUT_PULLUP);
  pinMode(R, OUTPUT);
  pinMode(I, OUTPUT);
  pinMode(C, OUTPUT);
  pinMode(K, OUTPUT);
  pinMode(Y, OUTPUT);
  pinMode(D, OUTPUT);
  pinMode(A, OUTPUT);
  pinMode(L, OUTPUT);
  pinMode(E, OUTPUT);
  switch (scene) {
    case 0:
      digitalWrite(R, LOW);
      digitalWrite(I, LOW);
      digitalWrite(C, LOW);
      digitalWrite(K, LOW);
      digitalWrite(Y, LOW);
      digitalWrite(D, LOW);
      digitalWrite(A, LOW);
      digitalWrite(L, LOW);
      digitalWrite(E, LOW);
      delay(50);
      digitalWrite(R, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(I, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(C, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(K, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(Y, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(D, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(A, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(L, HIGH);
      myDelay (100);
      myDelay (100);
      digitalWrite(E, HIGH);
      myDelay (100);
      myDelay (100);
    case 1:
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
    case 2:
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
      myDelay(100);
    case 3:
      myDelay(100);
      myDelay(100);
void myDelay(int delayTime) {
  if (digitalRead(select) == LOW) {
    scene++;
    if (scene > maxScene) {
      scene = 0;
  delay(delayTime);
Final product, working as I wanted. I'm sure there is an easier way to do this, but I'm happy with it.
Thank you all for the help.
Grumpy_Mike
#16
Aug 31, 2017, 12:51 am Last Edit: Aug 31, 2017, 02:05 am by Grumpy_Mike
Your myDelay function is quite frankly rubbish. The idea is to remove ALL delay calls and you still have one in the myDelay function.
That function should hold in a loop until the delay time is finished as measured by the millis timer OR the push button has been pressed.
Do not try any push counting in this functionality.
Girishchenna
I was also trying the same kind of programming, I am not successful with it. Scene is not switching to different cases.
I tried your above codes with my board as it is, only one case is working other two are not worked.
could you succeed with the above code?
