Topic: Please give advice. A problem occurred when setting the ADC sample point. (Read 1 time) previous topic - next topic
chaiwon89
Hello, I'm interested in sensor using Arduino Due ADC.
I used other people's ADC and FFT codes.
https://forum.arduino.cc/index.php?topic=137635.0
http://forum.arduino.cc/index.php?topic=225204.0
So, this is my code. (Sample rate : 1M, sample points : 2048 or 2000)
Quote
Code: [Select]
#define   SMP_RATE          1000000UL
#define   CLK_MAIN       84000000UL
#define   TMR_CNTR       CLK_MAIN / (2 *SMP_RATE)
#define   INP_BUFF  2048
volatile   uint16_t   sptr              =   0 ;
volatile    int16_t   flag              =   0 ;
           uint16_t  inp[2][INP_BUFF]   = { 0};
volatile   uint16_t   i = 1;
  adc_setup ();
  tmr_setup ();
  pinMode(2,INPUT);
  while(1)
    Serial.print(inp[0][i]);
    if(i==INP_BUFF)
      i++;
  //Serial.print(FFT_SIZE);  //2048
void pio_TIOA0 ()  // Configure Ard pin 2 as output from TC0 channel A (copy of trigger event)
  PIOB->PIO_PDR = PIO_PB25B_TIOA0 ;  // disable PIO control
  PIOB->PIO_IDR = PIO_PB25B_TIOA0 ;   // disable PIO interrupts
  PIOB->PIO_ABSR |= PIO_PB25B_TIOA0 ;  // switch to B peripheral
void tmr_setup ()
  pmc_enable_periph_clk(TC_INTERFACE_ID + 0 *3 + 0); // clock the TC0 channel 0
  TcChannel * t = &(TC0->TC_CHANNEL)[0] ;            // pointer to TC0 registers for its channel 0
  t->TC_CCR = TC_CCR_CLKDIS ;                        // disable internal clocking while setup regs
  t->TC_IDR = 0xFFFFFFFF ;                           // disable interrupts
  t->TC_SR ;                                         // read int status reg to clear pending
  t->TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1 |           // use TCLK1 (prescale by 2, = 42MHz)
              TC_CMR_WAVE |                          // waveform mode
              TC_CMR_WAVSEL_UP_RC |                  // count-up PWM using RC as threshold
              TC_CMR_EEVT_XC0 |     // Set external events from XC0 (this setup TIOB as output)
              TC_CMR_ACPA_CLEAR | TC_CMR_ACPC_CLEAR |
              TC_CMR_BCPB_CLEAR | TC_CMR_BCPC_CLEAR ;
  t->TC_RC = TMR_CNTR;              // counter resets on RC, so sets period in terms of 42MHz clock
  t->TC_RA = TMR_CNTR /2;           // roughly square wave
  t->TC_CMR = (t->TC_CMR & 0xFFF0FFFF) | TC_CMR_ACPA_CLEAR | TC_CMR_ACPC_SET ;  // set clear and set from RA and RC compares
  t->TC_CCR = TC_CCR_CLKEN | TC_CCR_SWTRG ;  // re-enable local clocking and switch to hardware trigger source.
void adc_setup ()
  pmc_enable_periph_clk(ID_ADC);  // pmc : power management controller
  adc_init(ADC, SystemCoreClock, 42000000UL, ADC_STARTUP_FAST);
  NVIC_EnableIRQ (ADC_IRQn);               // enable ADC interrupt vector      IRQ : Interrupt ReQuest 164page
  adc_disable_all_channel(ADC);
  adc_enable_interrupt(ADC, ADC_IER_RXBUFF);    //ADC_IER : (write only) ADC interrupt enable register, RXBUFF : receive buffer full interrupt enable
  ADC->ADC_RPR  =  (uint32_t)  inp[0];      // DMA buffer
  ADC->ADC_RCR  =  INP_BUFF;
  ADC->ADC_RNPR =  (uint32_t)  inp[1];      // next DMA buffer
  ADC->ADC_RNCR =  INP_BUFF;
  ADC->ADC_PTCR =  1;
  adc_set_bias_current(ADC, 0x01);
  //  adc_enable_tag(ADC);
  adc_enable_channel(ADC, ADC_CHANNEL_7);  // AN0
  adc_configure_trigger(ADC, ADC_TRIG_TIO_CH_0, 0);
  adc_start(ADC);
void ADC_Handler (void)
  if((adc_get_status(ADC) & ADC_ISR_RXBUFF) == ADC_ISR_RXBUFF) {
    flag = ++sptr;
    sptr &=  0x01;
    ADC->ADC_RNPR  =  (uint32_t)  inp[sptr];
I tested ADC by applying a signal with Signal Generator(20kHZ 300mVpp sine wave).
When I set sample points 2000(or 100, 500, 1000), there was not problem.
Quote
#define   INP_BUFF  2000
After data acquisition and plotting in MATLAB, I can get clear sine wave. [Figure 1]
Quote
However, when I set sample points 2048(or 512, 1024) and use ADC, the plotted sine wave was very distorted. [Figure 2]
In my project, I should use FFT function. So, I should use not 2000(or 100, 500, 1000) points but 2048(or 1024) points.
Is there any problem in my code and ADC setting? I don't know how to solve it.
Please give me your advice. I will listen sincerely.
MasterT
I can see a few issues with adaptation of the code:
1. You can't transfer data with rate 1Msps x 16 = 16 000 000 (!!!) bit/sec over serial link with baud rate 115 200 bit/sec.
2. ADC is overclocked more than twice.
3. Original code used "ping-pong" two buffers configuration,  to run sampling and conversion simultaneously real-time.
   That was make sense for lower sampling rate, limited by arduino DUE capability to process data. In your case, speed would be  limited by serial link, see 1
4. Arduino DUE ADC is not capable to sample 1 Msps sharp in not free-running mode, upper limit about 950 ksps.
ard_newbie
Hello chaiwon89,
I enclosed a few thoughts about your code, although It will not be sufficient for a reliable sketch... :
Code: [Select]
/***********  Comment this line when not using Serial USB   **************/
//#define Serial SerialUSB
// *************** There is a bug in ADC_STARTUP_FAST init, it should not be 768 periods of ADC CLOCK see page 1334. I set 8 periods instead
#define   ADC_STARTUP_FAST (ADC_MR_STARTUP_SUT8)
// ************* Always use braces for #define
#define   SMP_RATE       (1000000UL)
#define   CLK_MAIN       (84000000UL)
#define   TMR_CNTR       (CLK_MAIN / (2 *SMP_RATE))
#define   INP_BUFF      (2048)
volatile   uint16_t   sptr; // ******=   0 ;
//************* volatile    int16_t   flag              =   0 ;
  // **********Serial.begin(115200);
  Serial.begin(250000);
  while (!Serial); // ************** Irrelevant for Serial but necessary for SerialUSB
  adc_setup ();
  tmr_setup ();
  pinMode(2, INPUT);
// ***  shouldn't it be in loop to run repeatedly with plotter serial ???
  while (1)
    Serial.println(inp[0][i]);
    // ************Serial.println();
    if (i == INP_BUFF)
      i++;
void pio_TIOA0 ()  // Configure Ard pin 2 as output from TC0 channel *****  0  ****** (copy of trigger event)
void tmr_setup ()
  pmc_enable_periph_clk(TC_INTERFACE_ID + 0 * 3 + 0); // clock  TC0 channel 0
  //****** First init of TC0->TC_CHANNEL[0].TC_CMR
              TC_CMR_EEVTEDG_RISING | //******** Set external event Edge selection, e.g. on Rising
              //****** what is output on TIOA after this ???
  t->TC_RA = TMR_CNTR / 2;          // roughly square wave
  //******** You are doing a new initialization of TC0->TC_CHANNEL[0].TC_CMR ??
  t->TC_CCR = TC_CCR_CLKEN | TC_CCR_SWTRG ;  // ****  Enable local clocking and switch to hardware trigger source.
void adc_setup ()
  //*********************** adc_init(ADC, SystemCoreClock, 42000000UL, ADC_STARTUP_FAST);
  // ***** ADC_FREQ_MAX = 20 MHz
  adc_init(ADC, SystemCoreClock, ADC_FREQ_MAX, ADC_STARTUP_FAST);
  sptr = 1;                         //*********************************
  ADC->ADC_PTCR |= ADC_PTCR_RXTEN;        // ****** Enable PDC receiver channel request  *********************
  //*************adc_enable_channel(ADC, ADC_CHANNEL_7);  // AN0
  ADC->ADC_CHER = ADC_CHER_CH7;             // Enable Channel 7 = A0
  //**********  Trigger selection on TIOA Output of the Timer Counter Channel 0
  ADC->ADC_MR |=  ADC_MR_TRGEN | ADC_MR_TRGSEL_ADC_TRIG1 | ADC_MR_FREERUN_OFF;
  // *************** adc_configure_trigger(ADC, ADC_TRIG_TIO_CH_0, 0);
  adc_start(ADC);
  if ((adc_get_status(ADC) & ADC_ISR_RXBUFF) ==  ADC_ISR_RXBUFF) {
    //***************************  flag = ++sptr;
    sptr =  (sptr + 1) % 2; // *************************** sptr = 0 or 1
chaiwon89
Thank you MasterT.
I understand your comment.
I understand that I have to reduce the sample rate to match the maximum speed of the Serial.
Then, how much should we reduce the sample rate?
chaiwon89
Thank you ard_newbie.
I checked your code.
Code: [Select]
Your code use 250000 bit/sec serial communication, but as you know, it exceed the limitation of maximum speed of sketch...
How can I see the result of your code operation?
MasterT
Depends on receiving computer, what software application you have at the other end. I read somewhere on this forum , that arduino DUE was able to stream data about 1Mbits/s over serialUSB.
Basic serial link with speed 115200 'd provide no more than 115200/ 16 (two bytes based on 12-bits ADC result) = 7200 kHz, it's quite rough approximation, realistically value will be lower
