Hi
I am running ubuntu, and these are the codes i am currently using:
My problem is that the LED reacts (flickers) when i send a message to the arduino using the first code below, but it does not produce the expected results.The LED should blink as many times as the number i sent to the arduino instead it only flickers when i send the number to it and does nothing else. BUT when the serial monitor is on, i works correctly...
Yes i have the correct baud
yes i have uploaded the code on the arduino =P
I am new in this subject so any help is appreciated!
ALL CODES ARE COPIED FROM AN ONLINE TUTORIAL
[code]/*
* Arduino-serial
* A simple command-line example program showing how a computer can
* communicate with an Arduino board. Works on any POSIX system (Mac/Unix/PC)
* Compile with something like:
* gcc -o arduino-serial arduino-serial.c
* Created 5 December 2006
* Copyleft (c) 2006, Tod E. Kurt, tod@todbot.com
* http://todbot.com/blog/
* Updated 8 December 2006:
* Justin McBride discoevered B14400 & B28800 aren't in Linux's termios.h.
* I've included his patch, but commented out for now. One really needs a
* real make system when doing cross-platform C and I wanted to avoid that
* for this little program. Those baudrates aren't used much anyway. :)
* Updated 26 December 2007:
* Added ability to specify a delay (so you can wait for Arduino Diecimila)
* Added ability to send a binary byte number
* Update 31 August 2008:
* Added patch to clean up odd baudrates from Andy at hexapodia.org
#include <stdio.h> /* Standard input/output definitions */
#include <stdlib.h>
#include <stdint.h> /* Standard types */
#include <string.h> /* String function definitions */
#include <unistd.h> /* UNIX standard function definitions */
#include <fcntl.h> /* File control definitions */
#include <errno.h> /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <sys/ioctl.h>
#include <getopt.h>
void usage(void);
int serialport_init(const char* serialport, int baud);
int serialport_writebyte(int fd, uint8_t b);
int serialport_write(int fd, const char* str);
int serialport_read_until(int fd, char* buf, char until);
void usage(void) {
printf("Usage: arduino-serial -p <serialport> [OPTIONS]\n"
"\n"
"Options:\n"
" -h, --help Print this help message\n"
" -p, --port=serialport Serial port Arduino is on\n"
" -b, --baud=baudrate Baudrate (bps) of Arduino\n"
" -s, --send=data Send data to Arduino\n"
" -r, --receive Receive data from Arduino & print it out\n"
" -n --num=num Send a number as a single byte\n"
" -d --delay=millis Delay for specified milliseconds\n"
"\n"
"Note: Order is important. Set '-b' before doing '-p'. \n"
" Used to make series of actions: '-d 2000 -s hello -d 100 -r' \n"
" means 'wait 2secs, send 'hello', wait 100msec, get reply'\n"
"\n");
int main(int argc, char *argv[])
int fd = 0;
char serialport[256];
int baudrate = B9600; // default
char buf[256];
int rc,n;
if (argc==1) {
usage();
exit(EXIT_SUCCESS);
/* parse options */
int option_index = 0, opt;
static struct option loptions[] = {
{"help", no_argument, 0, 'h'},
{"port", required_argument, 0, 'p'},
{"baud", required_argument, 0, 'b'},
{"send", required_argument, 0, 's'},
{"receive", no_argument, 0, 'r'},
{"num", required_argument, 0, 'n'},
{"delay", required_argument, 0, 'd'}
while(1) {
opt = getopt_long (argc, argv, "hp:b:s:rn:d:",
loptions, &option_index);
if (opt==-1) break;
switch (opt) {
case '0': break;
case 'd':
n = strtol(optarg,NULL,10);
usleep(n * 1000 ); // sleep milliseconds
break;
case 'h':
usage();
break;
case 'b':
baudrate = strtol(optarg,NULL,10);
break;
case 'p':
strcpy(serialport,optarg);
fd = serialport_init(optarg, baudrate);
if(fd==-1) return -1;
break;
case 'n':
n = strtol(optarg, NULL, 10); // convert string to number
rc = serialport_writebyte(fd, (uint8_t)n);
if(rc==-1) return -1;
break;
case 's':
strcpy(buf,optarg);
rc = serialport_write(fd, buf);
break;
case 'r':
serialport_read_until(fd, buf, '\n');
printf("read: %s\n",buf);
break;
exit(EXIT_SUCCESS);
} // end main
int serialport_writebyte( int fd, uint8_t b)
int n = write(fd,&b,1);
if( n!=1)
return -1;
return 0;
int len = strlen(str);
int n = write(fd, str, len);
if( n!=len )
return -1;
return 0;
char b[1];
int i=0;
do {
int n = read(fd, b, 1); // read a char at a time
if( n==-1) return -1; // couldn't read
if( n==0 ) {
usleep( 10 * 1000 ); // wait 10 msec try again
continue;
buf[i] = b[0]; i++;
} while( b[0] != until );
buf[i] = 0; // null terminate the string
return 0;
// takes the string name of the serial port (e.g. "/dev/tty.usbserial","COM1")
// and a baud rate (bps) and connects to that port at that speed and 8N1.
// opens the port in fully raw mode so you can send binary data.
// returns valid fd, or -1 on error
struct termios toptions;
int fd;
//fprintf(stderr,"init_serialport: opening port %s @ %d bps\n",
// serialport,baud);
fd = open(serialport, O_RDWR | O_NOCTTY | O_NDELAY);
if (fd == -1) {
perror("init_serialport: Unable to open port ");
return -1;
if (tcgetattr(fd, &toptions) < 0) {
perror("init_serialport: Couldn't get term attributes");
return -1;
speed_t brate = baud; // let you override switch below if needed
switch(baud) {
case 4800: brate=B4800; break;
case 9600: brate=B9600; break;
#ifdef B14400
case 14400: brate=B14400; break;
#endif
case 19200: brate=B19200; break;
#ifdef B28800
case 28800: brate=B28800; break;
#endif
case 38400: brate=B38400; break;
case 57600: brate=B57600; break;
case 115200: brate=B115200; break;
cfsetispeed(&toptions, brate);
cfsetospeed(&toptions, brate);
// 8N1
toptions.c_cflag &= ~PARENB;
toptions.c_cflag &= ~CSTOPB;
toptions.c_cflag &= ~CSIZE;
toptions.c_cflag |= CS8;
// no flow control
toptions.c_cflag &= ~CRTSCTS;
toptions.c_cflag |= CREAD | CLOCAL; // turn on READ & ignore ctrl lines
toptions.c_iflag &= ~(IXON | IXOFF | IXANY); // turn off s/w flow ctrl
toptions.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); // make raw
toptions.c_oflag &= ~OPOST; // make raw
// see: http://unixwiz.net/techtips/termios-vmin-vtime.html
toptions.c_cc[VMIN] = 0;
toptions.c_cc[VTIME] = 20;
if( tcsetattr(fd, TCSANOW, &toptions) < 0) {
perror("init_serialport: Couldn't set term attributes");
return -1;
return fd;
[/code]
the second code
* Serial Read Blink
* Turns on and off a light emitting diode(LED) connected to digital
* pin 13. The LED will blink the number of times given by a
* single-digit ASCII number read from the serial port.
* Created 18 October 2006
* copyleft 2006 Tod E. Kurt <tod@todbot.com>
* based on "serial_read_advanced" example
int ledPin = 13; // select the pin for the LED
int val = 0; // variable to store the data from the serial port
pinMode(ledPin,OUTPUT); // declare the LED's pin as output
Serial.begin(9600); // connect to the serial port
void loop () {
val = Serial.read(); // read the serial port
// if the stored value is a single-digit number, blink the LED that number
if (val > '0' && val <= '9' ) {
val = val - '0'; // convert from character to number
for(int i=0; i<val; i++) {
Serial.println("blink!");
digitalWrite(ledPin,HIGH);
delay(150);
digitalWrite(ledPin, LOW);
delay(150);
//Serial.println();
