Hello, thanks for answering.
The application changes are just what I have listed above. The LCD library is different however - it is the I2C version.
I have added a few defines to mnap the buttons onto my Mega256 board etc. Otherwis the code is the example code.
//MENWIZ ESAMPLE
#include <Wire.h>
//INSERT ALL THE FOLLOWING 5 INCLUDES AFTER INCLUDING WIRE LIB
#include <LCD.h>
#include <buttons.h>
#include <MENWIZ.h>
#include <EEPROM.h> // to be included only if defined EEPROM_SUPPORT
// DEFINE ARDUINO PINS FOR THE NAVIGATION BUTTONS
//#define UP_BUTTON_PIN 9
//#define DOWN_BUTTON_PIN 10
//#define LEFT_BUTTON_PIN 7
//#define RIGHT_BUTTON_PIN 8
//#define CONFIRM_BUTTON_PIN 12
//#define ESCAPE_BUTTON_PIN 11
#define UP_BUTTON_PIN 42
#define DOWN_BUTTON_PIN 46
#define LEFT_BUTTON_PIN 50
#define RIGHT_BUTTON_PIN 34
#define CONFIRM_BUTTON_PIN 26
#define ESCAPE_BUTTON_PIN 30
//Create global object menu and lcd
//menwiz menu;
//LiquidCrystal_I2C lcd(0x20, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Addr, En, Rw, Rs, d4, d5, d6, d7, backlighpin, polarity
/*-----( Declare Constants )-----*/
#define I2C_ADDR 0x20 // Define I2C Address for the PCF8574T
//---(Following are the PCF8574 pin assignments to LCD connections )----
// This are different than earlier/different I2C LCD displays
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define LED_OFF 1
#define LED_ON 0
menwiz menu;
/*-----( Declare objects )-----*/
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
int timerPin = 8;
//instantiate global variables to bind to menu
int tp=0;
float f=26.0;
boolean bb=0;
byte b=50;
void setup(){
_menu *r,*s1,*s2;
_var *v;
int mem;
pinMode(timerPin, OUTPUT); //Setup the pin to
Serial.begin(19200);
// have a look on memory before menu creation
Serial.println(sizeof(menwiz));
mem=menu.freeRam();
// inizialize the menu object (20 colums x 4 rows)
menu.begin(&lcd,20,4);
//menu.setBehaviour(MW_MENU_INDEX,false);
//create the menu tree
r=menu.addMenu(MW_ROOT,NULL,F("MAIN MENU")); //create a root menu at first (required)
s1=menu.addMenu(MW_SUBMENU,r,F("MEASURE SUBMENU")); //add a child (submenu) node to the root menu
//s1->setBehaviour(MW_MENU_COLLAPSED,true);
s2=menu.addMenu(MW_VAR,s1,F("list")); //add a terminal node (that is "variable");
s2->addVar(MW_LIST,&tp); //create a variable of type "option list"..
s2->addItem(MW_LIST,F("option 1")); //add option to the OPTION LIST
s2->addItem(MW_LIST,F("option 2")); //add option to the OPTION LIST
s2->addItem(MW_LIST,F("option 3")); //add option to the OPTION LIST
s2->addItem(MW_LIST,F("option 4")); //add option to the OPTION LIST
s2->addItem(MW_LIST,F("option 5")); //add option to the OPTION LIST
// s2->setBehaviour(MW_SCROLL_HORIZONTAL,true);
// s2->setBehaviour(MW_LIST_2COLUMNS,true);
// s2->setBehaviour(MW_LIST_3COLUMNS,true);
s2=menu.addMenu(MW_VAR,s1,F("float var")); //add a terminal node (that is "variable");
s2->addVar(MW_AUTO_FLOAT,&f,11.00,100.00,0.5); //create a variable of type "float number"...
//...associated to the terminal node and bind it to the app variable "f" of type float
s2=menu.addMenu(MW_VAR,s1,F("byte var")); //add a terminal node (that is "variable");
s2->addVar(MW_AUTO_BYTE,&b,25,254,10); //create a variable of type "byte"...
//...associated to the terminal node and bind it to the app variable "b" of typr byte
s2=menu.addMenu(MW_VAR,s1,F("boolean var")); //add a terminal node (that is "variable");
s2->addVar(MW_BOOLEAN,&bb); //create a variable of type "boolean"
//...associated to the terminal node and bind it to the app variable "bb" of type boolean
s1=menu.addMenu(MW_VAR,r,F("WRITE TO SERIAL")); //add a terminal node (that is "variable") create an "action" associated to the terminal node...
s1->addVar(MW_ACTION,act); //the act function as default will be called when enter button is pushed
// s1->setBehaviour(MW_ACTION_CONFIRM,false); //...if you don't need action confirmation
s1=menu.addMenu(MW_VAR,r,F("SAVE TO EPROM")); //add a terminal node (that is "variable") create an "action" associated to the terminal node...
s1->addVar(MW_ACTION,savevar); //the act function as default will be called when enter button is pushed
s1=menu.addMenu(MW_VAR,r,F("LOAD FROM EEPROM")); //add a terminal node (that is "variable") create an "action" associated to the terminal node...
s1->addVar(MW_ACTION,loadvar); //the act function as default will be called when enter button is pushed
//declare navigation buttons (required)
menu.navButtons(UP_BUTTON_PIN,DOWN_BUTTON_PIN,ESCAPE_BUTTON_PIN,CONFIRM_BUTTON_PIN);
//(optional)create a user define screen callback to activate after 10 secs (10.000 millis) since last button push
menu.addUsrScreen(msc,10000);
//(optional) create a splash screen (duration 5.000 millis)with some usefull infos the character \n marks end of LCD line
//(tip): use preallocated internal menu.sbuf buffer to save memory space!
// sprintf(menu.sbuf,"MENWIZ TEST V %s\n.Free mem. :%d\n.Used mem :%d\n.Lap secs :%d",menu.getVer(),menu.freeRam(),mem-menu.freeRam(),5);
// menu.addSplash((char *) menu.sbuf, 5000);
void loop(){
digitalWrite(timerPin, digitalRead(timerPin) ^ 1);
menu.draw();
//PUT APPLICATION CODE HERE (if any)
// user defined callbacks
// WARNING avoid sprintf usage: it requires > 1.5 kbytes of memory!
void msc(){
static char buf[7];
strcpy(menu.sbuf,"User screen"); //1st lcd line
strcat(menu.sbuf,"\nUptime (s): ");strcat(menu.sbuf,itoa((unsigned int)(millis()/1000),buf,10));//2nd lcd line
strcat(menu.sbuf,"\nFree mem : ");strcat(menu.sbuf,itoa((int)menu.freeRam(),buf,10));//3rd lcd line
strcat(menu.sbuf,"\n"); //4th lcd line (empty)
menu.drawUsrScreen(menu.sbuf);
void act(){
Serial.println("FIRED ACTION!");
void savevar(){
menu.writeEeprom();
void loadvar(){
menu.readEeprom();
I don't think I've altered anything else but I'm about to check just to be sure.
Tnank you again for your efforts, David.
