Sometimes cheap is fine
There are two versions (at least) of the mjkdz board. The one you have is the 22 turn trimmer and has address 0x20 by default. The other one has a single turn pot and is 0x27 by default. I have both and have worked through connection issues just like you.
First, download the New Liquid Crystal library - https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
Make sure you remove the existing standard LiquidCrystal and LiquidCrystal_I2C libraries. Don't just rename them, you have to remove them from the 'libraries' folder completely or there will be a conflict.
If your LCD connections are (Left to Right) - VSS, VDD, VO, RS, RW, E, D0, D1, D2, D3, D4, D5, D6, D7, A (or LED+), K (or LED-) then the connection goes to the following bits on the I2C chip
RS - 6
RW - 5
E - 4
D4 - 0
D5 - 1
D6 - 2
D7 - 3
Backlight - 7
This makes your constructor 4,5,6,0,1,2,3,7 so use the following example sketch:-
#include <Wire.h>
#define lcdAddr 0x20 // set the address of the I2C device the LCD is connected to
// create an lcd instance with correct constructor for how the lcd is wired to the I2C chip
LiquidCrystal_I2C lcd(lcdAdrr, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE); // addr, EN, RW, RS, D4, D5, D6, D7, Backlight, POLARITY
// Creat a set of new characters
const uint8_t charBitmap[][8] = {
{ 0xc, 0x12, 0x12, 0xc, 0, 0, 0, 0 },
{ 0x6, 0x9, 0x9, 0x6, 0, 0, 0, 0 },
{ 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0, 0x0 },
{ 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0, 0x0 },
{ 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0x0 },
{ 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0x0 },
{ 0x0, 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0x0 },
{ 0x0, 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0x0 }
int charBitmapSize = (sizeof(charBitmap ) / sizeof (charBitmap[0]));
lcd.begin(20,4); // initialize the lcd as 20x4 (16,2 for 16x2)
lcd.setBacklight(1); // switch on the backlight
for ( int i = 0; i < charBitmapSize; i++ )
lcd.createChar ( i, (uint8_t *)charBitmap[i] );
lcd.home (); // go home to character 0 on line 0 (1st line)
lcd.print("Hello, ARDUINO ");
lcd.setCursor(0,1); // character 0 on line 1 (2nd line)
lcd.print (" FORUM - fm ");
lcd.setCursor(0,2) // character 0 on line 2 (3rd line)
lcd.print("This is line 3");
lcd.setCursor(0,3) // character 0 on line 3 (4th line)
lcd.clear()
lcd.home ();
// Do a little animation by writing to the same location
for ( int i = 0; i < 2; i++ )
for ( int j = 0; j < 16; j++ )
lcd.print (char(random(7)));
lcd.setCursor ( 0, 1 );
delay (200);
I've just modified that on the fly (mine are 16x2 LCD's) so hopefully it will work straight off for you. If not then look on it as a learning exercise to fix it, now you have the example
