Yes, if you want you can have a single array of button pin numbers.
Have a look at the tutorials and examples.
Ah, so if I use:
int buttonPins[] = {2, 3, 4, 5, 6};
I can use that to step iteratively through the input scanning routine?
I'd prefer to see const int buttonPins[] = {2, 3, 4, 5, 6};
but yes, that will work.
So, CheckInputs would be:
void CheckInputs (boolean screen)
int i;
for (i = 2; i <=6; i++)
boolean inputstatus = false;
inputstatus = digitalRead(buttonPins[i]);
if (inputstatus)
Serial.println("Input " i " depressed");
inputflag = true;
if (i != 6)
if (!inputflag)
Serial.println("Contestant " i-1 " buzzed!");
inputflag = true;
else;
else;
else;
if (!inputflag && screen)
Serial.println("No inputs depressed");
else;
return;
Not every if statement needs an else. If the else is not doing anything, get rid of it.
The else; look like errors. At least, errors waiting to happen.
digitalRead(buttonPins[glow][[/glow]i[glow]][/glow]);
It's an array, not a function.
Not much point initiailising the flag, if you're going to overwrite it:
boolean inputstatus = digitalRead(buttonPins[i]);
Also, be careful, C subscripts normally start from zero.
These do. If you read through the function's logic you'll see that they are all dependent on one another. There was yet another if...else in there, but I managed to refactor them into one. Unfortunately, that was the only one I have been able to refactor without breaking the logic. If you can find a way to reorganise it and have it perform the same function, I would appreciate the help.
The original code compiles with no errors, so I transposed it almost verbatim, editing for the differences in syntax between C and Arduino. If the Arduino compiler throws a hissy fit, it's due to its interpretation of the C language, not my initial code.
Good catch, thanks.
Unless of course, you need it resetting at the beginning of each loop.
The "else;"s do nothing - the fact that there's a semicolon after them signals that.
They are redundant, as is the "return;".
But you overwrite it at the beginning of every loop!
Just because a bit of code compiles without errors doesn't mean it doesn't harbour potential nasties.
Most languages allow you to shoot yourself in the foot, but C hands you the gun.
If you cut out redundant code, you leave fewer dark corners for the bugs to hide.
So they are, just test compiled the original code without them and it returned no errors.
D'oh!
Just goes to show how useful it is having an objective pair of eyes go over your code, lol.
void CheckInputs(boolean screen = true); //passes a true value to screen
//and sets CheckInputs to perform
//the initial input check.
boolean inputflag = false; //the initial input error check
boolean exitflag = false;
int x;
CheckInputs();
Serial.println("Initial Check Complete");
Serial.println("Enter number of questions");
x = Serial.read();
for (int i = 0; i < x; i++)
do
CheckInputs(false);
if (digitalRead(buttonPins[6]));
for (int a= 2; a <=6; a++)
digitalWrite(buttonPins[a], LOW);
inputflag = false;
exitflag = true;
} while (exitflag == false);
while (digitalRead(buttonPins[6]));
exitflag = false;
void CheckInputs(boolean screen)
int i;
if (inputstatus)
inputflag = true;
if (i != 6)
if (!inputflag)
inputflag = true;
OK, so this is how far I've got so far.
This doesn't compile, right?
It has errors around lines like:
which are not legal C or C++.
This would need to become
Serial.print("Input ");
Serial.print( i );
Serial.println(" depressed");
Also
is likely wrong, because the only valid indexes for buttonPins[] is 0 to 4.
HTH
GB
I think I've got it, got a clean compile with this:
int x;
CheckInputs();
x = Serial.read();
do
CheckInputs(false);
if (digitalRead(buttonPins[4]));
for (int a= 0; a <=4; a++)
inputflag = false;
exitflag = true;
while (digitalRead(buttonPins[4]));
exitflag = false;
int i;
for (i = 0; i <=4; i++)
if (inputstatus)
Serial.print(i+1);
inputflag = true;
if (i != 4)
if (!inputflag)
Serial.print("Contestant ");
Serial.print(i+1);
Serial.println(" buzzed!");
inputflag = true;
Hopefully, this will work.
EDIT: Nope, it just keeps looping through the initial check saying all inputs are pressed.
Pull-ups?
Pull-downs?
Well, for the contestant buttons, I'm using some handsets scavenged from an interactive DVD quiz game. These have 5 buttons, each with a different value resistor in series with it. The original control box used the different voltage potentials to distinguish which button had been pressed on each handset.
The only button I could get the Arduino to pick up when I tested it was the one with the 1K resistor.
if (digitalRead(buttonPins[4]))[glow];[/glow]
This isn't doing anything...
exitflag = true;
Doesn't look like exitFlag will ever get to be false.
Are the pins listed in buttonPins input or output? You are trying to use them as both.
You can't have it, with switches attached, both ways.
How are the switches wired?
Probably the simplest way is to use the AVR's internal pull-ups, but this inverts the logic of an open switch (It will be HIGH when open, and LOW when closed), but this is simple to deal with in software.
Without pull-ups or pull-downs, the pins are floating and can appear random.
Have a look at the examples and tutorials.
OK, I think that rather than try to shoehorn the old code into the Arduino, I'm going to have to rewrite this from scratch. stick with the code that works and use the K8055.
Thanks for all the help, but as the old adage goes, if it ain't broke, don't fix it.
I don't know about the other guys here, but I'm glad I didn't invest too much time in your day.
I felt a bit annoyed that I'd spent my limited time on someone who gave up, when I might have helped someone who made some progress instead. But I know who I'll avoid helping in future, and ...
I'm now quite pleased that I have an example thread where a simple program was made so complex that it defeated the author who claimed they'd got it working on different hardware.
In future I can reference this thread, and say "Rather than start with that complex old thing, take confidence from it that you can do it again, but instead start with a simple program. You will make progress faster. You might learn something new. It may even turn out much better! Sadly, this person didn't do that, and ended up giving up!"
Many silver linings are embedded in clouds ;D
GB
gbulmer, had I a cap to doff, I would doff it at you!
I like your attitude - you are obviously far less cynical than I. ;D
