Hi group,
i have a little problem with downloading from the IDE to optiboot (UNO) chip. Because of the nature of my project, I use the chip only (in my hardware) and a custom-made RS232/TTL converter. I added the "auto reset" circuitry, too (DTR to serial cap and a pullup of 10k).
For now, when I try to upload a sketch, I got a message "avrdude out of sync". The Pin13 led flashes correctly (3x, boot loader), when I loop back the TXD and RXD pins (at the level converter), I can "see myself" in a terminal program at the PC.
The oscilloscope shows a correct TTL serial data on TXD/RXD pins, the reset waveform at the RES pin looks good, too ...
But I can not download the binary object from IDE to chip ... When I hook up to the same wires (GND, RES, TXD, RXD) an empty Arduino UNO board and send there a compiled sketch, using the board's usbserial coverter, everything is okay.
Any idea? Thanks in forward.
