I am trying to connect an E-Ink display to my Arduino. Right now I am trying to figure out the best way of phyiscally connecting all the pins.
Does anyone have any suggestions on how to go about this?
Here are some images:
If someone has a good Idea on how to do hook this up, or where to buy this type of ribbon cable, I would apreceate it a lot.
Newhaven might have something that works : http://www.newhavendisplay.com/index.php?main_page=index&cPath=91_123
However, you are likely going to want to get a datasheet for that module. I imagine things will be easier when you know the pitch of the connector and the datasheet should also mention a type which should be googl-able. Also, I believe you are going to need to provide the display a high voltage in order to operate, another thing the datasheet could help with.
