Topic: Motor Control Problems (Read 202 times) previous topic - next topic
bubbles
Hi, my name is bubbles, (yes, hilarious my friends chose the name) and I have a project where I'm trying to run 5 motors at once. However, I seem to have trouble with the motors acting together.  There isn't a problem with the code or motors.  Can anyone help me out here? The code is attached below.
-Thank you Bubbles
#include <Servo.h>
Servo myservo1, myservo2, myservo3, myservo4, myservo5;
int pos = 0;
  myservo1.attach(9);
  myservo2.attach(8)
  myservo3.attach(7);
  myservo4.attach(6);
  myservo5.attach(5);
  for (pos = 0; pos <= 180; pos -= 2) {
    // in steps of 2 degrees
    myservo1.write(pos);
    delay(15);
   for (pos = 180; pos >= 0; pos += 2) {
     delay(15);
  myservo1.detach();
    myservo2.write(pos);
    delay(15);
     delay(15);
  myservo2.detach();
    myservo3.write(pos);
    delay(15);
     delay(15);
  myservo3.detach();
    myservo4.write(pos);
    delay(15);
     delay(15);
  myservo4.detach();
    myservo5.write(pos);
    delay(15);
     delay(15);
  myservo5.detach();
jremington
#1
Jan 08, 2018, 12:36 am Last Edit: Jan 08, 2018, 12:39 am by jremington
Please edit your post to add code tags ("</>" button), as described in the "How to use this forum" post.
At least 95% of the motor and servo problems posted on this forum are due to inadequate power supplies. For servos, you MUST use a separate 5-6V power supply, capable of supplying at least 1 Ampere per servo, so 5 Amperes total. Connect all the grounds together.
Finally, unless you know what you are doing, leave out all lines like this:
Code: [Select]
myservo1.detach();
slipstick
You know that code that there isn't a problem with?
Code: [Select]
How long does it take to get to 180 or more when you start at 0 and keep subtracting 2 from it?
At least you're consistent, every one is the same.
Steve
PaulS
Quote
That is NOT what the code you posted does.
Coding Badly
@bubbles, do not hijack.  Thread split.
@bubbles, do not cross-post.  Other thread locked: http://forum.arduino.cc/index.php?topic=521456.0
bubbles
Thank you for all of your help with these problems.  I have successfully corrected all the issues.
-bubbles
