Topic: Can arduino handle 3 sensor inputs? (Read 1 time) previous topic - next topic
yaantey
Hello,
Im planning to use arduino with 3 sensors which is moisture, temperature and motion. Also arduino should take a voice from a mic. So can arduino have a total of 4 inputs to it?
nevar91
Arduino┬┤s 328p has one serial link, 6 analog inputs and 12 digital pins that can be use as inputs as well.
I suppose voice module communicate through serial link and accelerometer as well. In theory it can works if you will write software correctly.....I think.
robtillaart
Quote
Can you tell more about this? And the overal goal of your project?
Arduino cannot detect voices or do text to speech or voice processing without additional hardware, at best it can detect a certain volume and with some fft it can derive some frequencies. you might use different whistles as commands, just like those sheepdogs
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
yaantey
Quote
Sure, all I want to do is mic to detect babys crying voice and cancel background noise (using amplification and filtering). And then arduino needs to transmit this voice to a receiver. Using a transmitter.
nevar91
You dont need arduino to do that. Here are more easier and less expensive ways...
cmiyc
That's well outside of the Arduino's capability.  "Cancel background noise" is a pretty heft DSP and is asking a lot for the ATmega's 2K of SRAM.  As already mentioned, there are better ways to transmit voice than using the Arduino.
You really don't need to effectively keep asking the same questions over and over:
http://arduino.cc/forum/index.php/topic,74586.msg562130.html#msg562130
http://arduino.cc/forum/index.php/topic,74811.msg563690.html#msg563690
http://arduino.cc/forum/index.php/topic,74825.msg563760.html#msg563760
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
