Topic: MAX7219 LED Matrix and 16*2 LCD Projects (Read 1 time) previous topic - next topic
patelhiren
Hello
I want to Scroll "Hello Word" on LCD Screen and same Scroll on LED Display, with using one arduino controller, it is possible?
Thanks,
xl97
In your mind...  (so we are all on the same page)
What is the differences between the:
LCD Screen?
LED Display?
The LCD is the 16x2?
and the
LED display is......?  what exactly?
From what I understand most of the LCD screens have a backpack on them so you can use serial or I2C...etc  and wont need anything else outside of the library.
If your LED display is a bunch of leds set-up like a 7-segement digit....
I would use the MAX72xx library to send the individual character/number to and have it output using the library.
However what & how your LED display is set up will be the dictating aspect..
patelhiren
Yes,
LCD - 16*2
LED - MAX7219 Dot LED Matrix display
Same image was attached.
CrossRoads
patelhiren
patelhiren
I try but it was showing below error.
exit status 1
Error compiling for board Arduino Nano.
Invalid library found in C:\Users\lbss4\Documents\Arduino\libraries\max7219-master: C:\Users\lbss4\Documents\Arduino\libraries\max7219-master
Grumpy_Mike
When you install a library you should remove the -master bit from the folder name.
patelhiren
I try, but some problem is there
#include "MaxMatrix.h"
#include "avr/pgmspace.h"
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
PROGMEM const unsigned char CH[] = {
3, 8, B00000000, B00000000, B00000000, B00000000, B00000000, // space 1, 8, B01011111, B00000000, B00000000, B00000000, B00000000, // !
3, 8, B00000011, B00000000, B00000011, B00000000, B00000000, // "
5, 8, B00010100, B00111110, B00010100, B00111110, B00010100, // # 4, 8, B00100100, B01101010, B00101011, B00010010, B00000000, // $ 5, 8, B01100011, B00010011, B00001000, B01100100, B01100011, // % 5, 8, B00110110, B01001001, B01010110, B00100000, B01010000, // & 1, 8, B00000011, B00000000, B00000000, B00000000, B00000000, // '
3, 8, B00011100, B00100010, B01000001, B00000000, B00000000, // ( 3, 8, B01000001, B00100010, B00011100, B00000000, B00000000, // ) 5, 8, B00101000, B00011000, B00001110, B00011000, B00101000, // * 5, 8, B00001000, B00001000, B00111110, B00001000, B00001000, // + 2, 8, B10110000, B01110000, B00000000, B00000000, B00000000, // , 4, 8, B00001000, B00001000, B00001000, B00001000, B00000000, // - 2, 8, B01100000, B01100000, B00000000, B00000000, B00000000, // .
4, 8, B01100000, B00011000, B00000110, B00000001, B00000000, // / 4, 8, B00111110, B01000001, B01000001, B00111110, B00000000, // 0 3, 8, B01000010, B01111111, B01000000, B00000000, B00000000, // 1 4, 8, B01100010, B01010001, B01001001, B01000110, B00000000, // 2 4, 8, B00100010, B01000001, B01001001, B00110110, B00000000, // 3 4, 8, B00011000, B00010100, B00010010, B01111111, B00000000, // 4 4, 8, B00100111, B01000101, B01000101, B00111001, B00000000, // 5 4, 8, B00111110, B01001001, B01001001, B00110000, B00000000, // 6 4, 8, B01100001, B00010001, B00001001, B00000111, B00000000, // 7 4, 8, B00110110, B01001001, B01001001, B00110110, B00000000, // 8 4, 8, B00000110, B01001001, B01001001, B00111110, B00000000, // 9 2, 8, B01010000, B00000000, B00000000, B00000000, B00000000, // :
2, 8, B10000000, B01010000, B00000000, B00000000, B00000000, // ; 3, 8, B00010000, B00101000, B01000100, B00000000, B00000000, // < 3, 8, B00010100, B00010100, B00010100, B00000000, B00000000, // = 3, 8, B01000100, B00101000, B00010000, B00000000, B00000000, // > 4, 8, B00000010, B01011001, B00001001, B00000110, B00000000, // ?
5, 8, B00111110, B01001001, B01010101, B01011101, B00001110, // @ 4, 8, B01111110, B00010001, B00010001, B01111110, B00000000, // A 4, 8, B01111111, B01001001, B01001001, B00110110, B00000000, // B 4, 8, B00111110, B01000001, B01000001, B00100010, B00000000, // C 4, 8, B01111111, B01000001, B01000001, B00111110, B00000000, // D 4, 8, B01111111, B01001001, B01001001, B01000001, B00000000, // E 4, 8, B01111111, B00001001, B00001001, B00000001, B00000000, // F 4, 8, B00111110, B01000001, B01001001, B01111010, B00000000, // G 4, 8, B01111111, B00001000, B00001000, B01111111, B00000000, // H 3, 8, B01000001, B01111111, B01000001, B00000000, B00000000, // I 4, 8, B00110000, B01000000, B01000001, B00111111, B00000000, // J 4, 8, B01111111, B00001000, B00010100, B01100011, B00000000, // K 4, 8, B01111111, B01000000, B01000000, B01000000, B00000000, // L 5, 8, B01111111, B00000010, B00001100, B00000010, B01111111, // M 5, 8, B01111111, B00000100, B00001000, B00010000, B01111111, // N 4, 8, B00111110, B01000001, B01000001, B00111110, B00000000, // O 4, 8, B01111111, B00001001, B00001001, B00000110, B00000000, // P 4, 8, B00111110, B01000001, B01000001, B10111110, B00000000, // Q 4, 8, B01111111, B00001001, B00001001, B01110110, B00000000, // R 4, 8, B01000110, B01001001, B01001001, B00110010, B00000000, // S 5, 8, B00000001, B00000001, B01111111, B00000001, B00000001, // T 4, 8, B00111111, B01000000, B01000000, B00111111, B00000000, // U 5, 8, B00001111, B00110000, B01000000, B00110000, B00001111, // V 5, 8, B00111111, B01000000, B00111000, B01000000, B00111111, // W 5, 8, B01100011, B00010100, B00001000, B00010100, B01100011, // X 5, 8, B00000111, B00001000, B01110000, B00001000, B00000111, // Y 4, 8, B01100001, B01010001, B01001001, B01000111, B00000000, // Z 2, 8, B01111111, B01000001, B00000000, B00000000, B00000000, // [ 4, 8, B00000001, B00000110, B00011000, B01100000, B00000000, // \ backslash 2, 8, B01000001, B01111111, B00000000, B00000000, B00000000, // ] 3, 8, B00000010, B00000001, B00000010, B00000000, B00000000, // hat 4, 8, B01000000, B01000000, B01000000, B01000000, B00000000, // _ 2, 8, B00000001, B00000010, B00000000, B00000000, B00000000, // ` 4, 8, B00100000, B01010100, B01010100, B01111000, B00000000, // a 4, 8, B01111111, B01000100, B01000100, B00111000, B00000000, // b 4, 8, B00111000, B01000100, B01000100, B00101000, B00000000, // c 4, 8, B00111000, B01000100, B01000100, B01111111, B00000000, // d 4, 8, B00111000, B01010100, B01010100, B00011000, B00000000, // e 3, 8, B00000100, B01111110, B00000101, B00000000, B00000000, // f 4, 8, B10011000, B10100100, B10100100, B01111000, B00000000, // g 4, 8, B01111111, B00000100, B00000100, B01111000, B00000000, // h 3, 8, B01000100, B01111101, B01000000, B00000000, B00000000, // i 4, 8, B01000000, B10000000, B10000100, B01111101, B00000000, // j 4, 8, B01111111, B00010000, B00101000, B01000100, B00000000, // k 3, 8, B01000001, B01111111, B01000000, B00000000, B00000000, // l 5, 8, B01111100, B00000100, B01111100, B00000100, B01111000, // m 4, 8, B01111100, B00000100, B00000100, B01111000, B00000000, // n 4, 8, B00111000, B01000100, B01000100, B00111000, B00000000, // o 4, 8, B11111100, B00100100, B00100100, B00011000, B00000000, // p 4, 8, B00011000, B00100100, B00100100, B11111100, B00000000, // q 4, 8, B01111100, B00001000, B00000100, B00000100, B00000000, // r 4, 8, B01001000, B01010100, B01010100, B00100100, B00000000, // s 3, 8, B00000100, B00111111, B01000100, B00000000, B00000000, // t 4, 8, B00111100, B01000000, B01000000, B01111100, B00000000, // u 5, 8, B00011100, B00100000, B01000000, B00100000, B00011100, // v 5, 8, B00111100, B01000000, B00111100, B01000000, B00111100, // w 5, 8, B01000100, B00101000, B00010000, B00101000, B01000100, // x 4, 8, B10011100, B10100000, B10100000, B01111100, B00000000, // y 3, 8, B01100100, B01010100, B01001100, B00000000, B00000000, // z 3, 8, B00001000, B00110110, B01000001, B00000000, B00000000, // { 1, 8, B01111111, B00000000, B00000000, B00000000, B00000000, // | 3, 8, B01000001, B00110110, B00001000, B00000000, B00000000, // } 4, 8, B00001000, B00000100, B00001000, B00000100, B00000000, // ~ };
int data = 6;    // DIN pin of MAX7219 module
int load = 7;    // CS pin of MAX7219 module
int clock = 8;  // CLK pin of MAX7219 module
int maxInUse = 3;  //how many MAX7219 are connected
MaxMatrix m(data, load, clock, maxInUse); // define Library
byte buffer[10];
char string1[] = "Electrical Department      ";  // Scrolling Text
void setup(){
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Electrical Department");
  delay(300);
  m.init(); // module MAX7219
  m.setIntensity(5); // LED Intensity 0-15 }
void loop(){
  //lcd.print("Electrical Dept");
  //delay(1000);
   // scroll 13 positions (string length) to the left
  // to move it offscreen left:
  for (int positionCounter = 0; positionCounter < 21; positionCounter++){
    // scroll one position left:
    lcd.scrollDisplayLeft();
    // wait a bit:
    delay(300);
    byte c;
  delay(100);
  m.shiftLeft(false, true);
  printStringWithShift(string1, 100);  // Send scrolling Text } // Put extracted character on Display void printCharWithShift(char c, int shift_speed) {
  if(c < 32) return;
  c -= 32;
  memcpy_P(buffer, CH + 7*c, 7);
  m.writeSprite(maxInUse*8, 0, buffer);
  m.setColumn(maxInUse*8 + buffer[0], 0);
  for (int i = 0; i < buffer[0]+1; i++)
    delay(shift_speed);
    m.shiftLeft(false, false);
// Extract characters from Scrolling text void printStringWithShift(char* s, int shift_speed){
  while (*s != 0){
    printCharWithShift(*s, shift_speed);
    s++;
Grumpy_Mike
That doesn't cut it here. What problem?
A compile error?
It runs but does not do what you expect? - if so what does it do?
patelhiren
my aim is "Electrical Department" first in LCD display and then LED display, and as per my aim working but after 3 scrolling in LCD display it was stop on Electric and then start scrolling in LED display.
LCD= 16*2 LCD display
LED = 8*8 LED matrix (MAX7219)
patelhiren
Almost all completed, but one new problem is there, anybody help me.
when i connect arduino with USB all working good, but when i connect arduino with other source, at that time only One LED (8*8 LED Matrix MAX7219) working.
thanks
patelhiren
patelhiren
patelhiren
