hi,
i spent hours trying to get arduino working with l298n hbridge chip
now i gave up i need help of yours please help
im trying to get to work a 5v motor with arduino and i want it to control it via arduino
i made all the connections same as explained on internet but it's not working
i took a photo of connection between l298 and arduino here it is: http://img707.imageshack.us/img707/1567/040720101288.jpg
please help im sure it is so easy for you fellows
i couldnt figure out which connection is incorrect as i am a electronics noobie
i also wrote some info on photo about which cable connected to where
int moto=2; //input1
int mt=3;//input 2
int a=4;// enable a
pinMode(a,OUTPUT);
pinMode(moto,OUTPUT);
pinMode(mt,OUTPUT);
digitalWrite(a,HIGH);
digitalWrite(moto,HIGH);
digitalWrite(mt,LOW);
delay(100);
digitalWrite(moto,LOW);
digitalWrite(mt,HIGH);
Pin 4 to a voltage supply, this will be either from the Arduino, or another power source.
Pin 8 to GND
Pin 9 to +5v from Arduino
Pin 10, 12 to a digital output each
Pin 11 to an analogue PWM output
Pin 13,14 are your outputs to the motor.
Pin 15 needs to be straight to GND with a very low 5Watt resistor.
Your photo looks very wrong and you could have damaged the L298 already.
what do you mean by a very low 5watt resistor?
what kinda resistor for example?
im really a beginner i dunno much about anything
i just went to electronics shop and they didnt come up with any resistor when i ask for a 5watt resistor
ok i bought 0.5 ohm 5 watt resistor
Pin 15 should be connected to the current sensing resistor with the other end to ground. This allows another chip to control the current through the motor and keep it at a safe level. The value of the resistor depends on what current your load is taking and what voltage the other chip takes. The power rating of a resistor is how much energy it can burn without overheating but to ask for a 5W resistor without a value is meaningless.
But as was pointed out you wired the power up backwards so it's probably fried by now.
yea it was overheated yesterday
i just bought a new one today
and bought a 0.47ohm 5 watt resistor
as i am a beginner do you think i better take a photo and share it here so you can tell me ok it's work or not
im afraid to burn this new one
thanks for all your helps
by the way is it ok if i connect both 9. ping and 4. pin which is supply voltage to arduino's 5v out
Sounds good.
Well pin 9 should be connected to the arduino's supply but pin 4 is for the motor's supply. If you connect it to the arduino you will be pulling the power for the motor through either the arduino's regulator or the USB socket. This is fine if the motor is only drawing a few hundred mA but anything over 300mA should be powered with a separate supply.
Also change:-
delay(100);
to delay(3000);
as a tenth of a second is not long enough to see the motor run.
As I said there is no need for a resistor if you don't have another chip controlling the current. Note also you need to connect pin 1 to ground as well even though you are not using the other side of the bridge.
Yes the chip is the L298, no need to replace anything else. Get the power round the right way this time.
You have not said how much current your motor takes, this is important for seeing where you power it from.
Ok on the current. That wiring looks wrong again. You label something Pin 9 to 5V ard and it is not going into pin 9 of the L298. Most other wires don't appear to be going to the right place.
All in all it looks like you are not getting the right wires identified in the L298, look at the data sheet again.
That is looking at the plastic side. Pin 1 is current sense A and is the first pin that sticks out from the package. So from your overhead view it should be on the lower row at the left hand side.
do you think this one may burn too? if i runned it that way
i runned it i couldnt stop myself till i get reply here.
i checked if it getting hot it didnt
i hope this one didnt burnt anyway im gonna try with correct connections this time lets hope it works
