The following errors are thrown by ver 12 on compile. Version 11 does not give any errors when compiling the same code.
\LOCALS~1\Temp\build20730.tmp\/_init.h: In function 'void ds_init()':
\LOCALS~1\Temp\build20730.tmp\/_init.h:31: error: 'INPUT' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:31: error: 'pinMode' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:36: error: 'OUTPUT' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:49: error: 'HIGH' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:49: error: 'digitalWrite' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:56: error: 'LOW' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:57: error: 'MSBFIRST' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:57: error: 'shiftOut' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:61: error: 'byte' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:61: error: expected `;'before 'i'
\LOCALS~1\Temp\build20730.tmp\/_init.h:61: error: 'i' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:64: error: 'delayMicroseconds' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:81: error: 'Serial' wasnot declared in this scope
In function 'void loop()':
Here is the code:
// Danger Board Gamma Corrected LED
// By: Zach Hoeken (hoeken@gmail.com)
// More info: make.nycresistor.com/ds-1.0#include <math.h>
#include "_init.h"
#include "_data.h"void setup()
ds_init();
}int raw1 = 0;
int raw2 = 0;
int raw3 = 0;int pwm1 = 0;
int pwm2 = 0;
int pwm3 = 0;
int pwm4 = 0;
int pwm5 = 0;int seg_value = 0;
long idle = 0;
byte idle_num = 0;void loop()
//read our sliders
raw1 = analogRead(SLIDER1_PIN);
raw2 = analogRead(SLIDER2_PIN);
raw3 = analogRead(SLIDER3_PIN);//correct for percieved brightness
//pwm1 = gamma_correct(raw1, 3.0);
//pwm2 = gamma_correct(raw2, 3.0);
//pwm3 = gamma_correct(raw3, 3.0);
pwm1 = 255;
pwm2 = 255;
pwm3 = 255;//make our leds run!
if (digitalRead(BUTTON1_PIN))
analogWrite(SLIDER1_LED_PIN, pwm1);
seg_value = map(raw1, 0, 1023, 0, 9);digitalWrite(BUZZER_PIN, HIGH);
delayMicroseconds(1500 + analogRead(SLIDER1_PIN));
digitalWrite(BUZZER_PIN, LOW);idle = 0;
analogWrite(SLIDER1_LED_PIN, 0);//make our leds run!
if (digitalRead(BUTTON2_PIN))
analogWrite(SLIDER2_LED_PIN, pwm2);
seg_value = map(raw2, 0, 1023, 0, 9);digitalWrite(BUZZER_PIN, HIGH);
delayMicroseconds(1000 + analogRead(SLIDER2_PIN));
analogWrite(SLIDER2_LED_PIN, 0);//make our leds run!
if (digitalRead(BUTTON3_PIN))
analogWrite(SLIDER3_LED_PIN, pwm3);
seg_value = map(raw3, 0, 1023, 0, 9);digitalWrite(BUZZER_PIN, HIGH);
delayMicroseconds(500 + analogRead(SLIDER3_PIN));
analogWrite(SLIDER3_LED_PIN, 0);seg_value = constrain(seg_value, 0, 9);
byte j = chardata[seg_value];digitalWrite(LATCH_PIN, LOW);
shiftOut(DATA_PIN, CLOCK_PIN, MSBFIRST, j);
digitalWrite(LATCH_PIN, HIGH);//our idle program.
idle++;
if (idle > 10000)
byte j = chardata[idle_num];digitalWrite(LATCH_PIN, LOW);
digitalWrite(LATCH_PIN, HIGH);digitalWrite(LED1_PIN, HIGH);
digitalWrite(LED2_PIN, LOW);
delay(250);
digitalWrite(LED2_PIN, HIGH);
digitalWrite(LED1_PIN, LOW);
delay(250);idle = 10001;
idle_num++;if (idle_num > 9)
idle_num = 0;
}byte gamma_correct(byte pwm, double gamma)
return (byte)(255.0 * pow(pwm/255.0, gamma));
I previously posted this in Troubleshooting, but it appears that it may actually be a bug in version 12. http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1224824424
