Topic: Scrolling LED Matrix code (Read 786 times) previous topic - next topic
PaulRB
Pick values for I, j & k and work though an example on paper. Use the reference page to find out about the "|" and ">>" operators.
cabyambo
@PaulRb I've made sense of that line of code and edited it a little so that spaces work properly. The only problem I have is that I'd like to make the space a shorter length. It's too much waiting currently, but I can't seem to figure out how to shorten it without messing up everything else. Would you happen to know how to do this?
Code: [Select]
const int rClock = 2; //chip pin 7
const int rData = 0; //chip pin 5
const int cData = 4; //chip pin 3
const int latch = 1; //chip pin 6
const int cClock = 3; //chip pin 2
//replaced with " bit(i) "
//byte rowActivator[] = {B10000000, B01000000, B00100000, B00010000, B00001000, B00000100, B00000010, B00000001};
//byte rowActivator[] = {B00000001, B00000010, B00000100, B00001000, B00010000, B00100000, B01000000, B10000000};
byte letters[27][8] =
  {B00000000, B00111000, B01000100, B01000100, B01000100, B01111100, B01000100, B01000100}, //A0
  {B00000000, B01111000, B01000100, B01000100, B01111000, B01000100, B01000100, B01111000}, //B1
  {B00000000, B00111000, B01000100, B01000000, B01000000, B01000000, B01000100, B00111000}, //C2
  {B00000000, B01110000, B01001000, B01000100, B01000100, B01000100, B01001000, B01110000}, //D3
  {B00000000, B01111100, B01000000, B01000000, B01111100, B01000000, B01000000, B01111100}, //E4
  {B00000000, B01111100, B01000000, B01000000, B01111000, B01000000, B01000000, B01000000}, //F5
  {B00000000, B01111000, B01000100, B01000000, B01011100, B01000100, B01000100, B00111100}, //G6
  {B00000000, B01000100, B01000100, B01000100, B01111100, B01000100, B01000100, B01000100}, //H7
  {B00000000, B01110000, B00100000, B00100000, B00100000, B00100000, B00100000, B01110000}, //I8
  {B00000000, B00011100, B00001000, B00001000, B00001000, B00001000, B01001000, B00110000}, //J9
  {B00000000, B01000100, B01001000, B01010000, B01100000, B01010000, B01001000, B01000100}, //K10
  {B00000000, B01000000, B01000000, B01000000, B01000000, B01000000, B01000000, B01111100}, //L11
  {B00000000, B01000100, B01101100, B01010100, B01010100, B01000100, B01000100, B01000100}, //M12
  {B00000000, B01000100, B01000100, B01100100, B01010100, B01001100, B01000100, B01000100}, //N13
  {B00000000, B00111000, B01000100, B01000100, B01000100, B01000100, B01000100, B00111000}, //O14
  {B00000000, B01111000, B01000100, B01000100, B01111000, B01000000, B01000000, B01000000}, //P15
  {B00000000, B00111000, B01000100, B01000100, B01000100, B01010100, B01001000, B00110100}, //Q16
  {B00000000, B01111000, B01000100, B01000100, B01111000, B01010000, B01001000, B01000100}, //R17
  {B00000000, B00111100, B01000000, B01000000, B00111000, B00000100, B00000100, B01111000}, //S18
  {B00000000, B01111100, B00010000, B00010000, B00010000, B00010000, B00010000, B00010000}, //T19
  {B00000000, B01000100, B01000100, B01000100, B01000100, B01000100, B01000100, B00111000}, //U20
  {B00000000, B01000100, B01000100, B01000100, B01000100, B01000100, B00101000, B00010000}, //V21
  {B00000000, B01000100, B01000100, B01000100, B01010100, B01010100, B01010100, B00101000}, //W22
  {B00000000, B01000100, B01000100, B00101000, B00010000, B00101000, B01000100, B01000100}, //X23
  {B00000000, B01000100, B01000100, B01000100, B00101000, B00010000, B00010000, B00010000}, //Y24
  {B00000000, B01111100, B00000100, B00001000, B00010000, B00100000, B01000000, B01111100}, //Z25
  {B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000}, // Space to shift 32
  //Serial.begin(9600); Isn't supported on the ATtiny85
  pinMode(rClock, OUTPUT);
  pinMode(rData, OUTPUT);
  pinMode(cData, OUTPUT);
  pinMode(latch, OUTPUT);
  pinMode(cClock, OUTPUT);
  scrollMessage(" HELLO WORLD ");
//function to clear the row registers preventing "ghosting"
void clrData()
  digitalWrite(latch, LOW);
  shiftOut(rData, rClock, LSBFIRST, B00000000);
  digitalWrite(latch, HIGH);
void displayLetter(char letter)
  for(int i=0; i<8; i++)
    clrData();
    shiftOut(rData, rClock, LSBFIRST, bit(i)); //bit(i) used to be row activator
    shiftOut(cData, cClock, LSBFIRST, letters[letter - 65][i]);
    delay(0);
//add a space to the end of the message
void scrollMessage(char* message)
  int scrollDelay = 130;
  for(int i = 0; i < strlen(message)-1; i++)
    for(int j=0; j<8; j++)
      unsigned long timer = millis();
      while(millis() - timer < scrollDelay)
        for(int m=0; m<8; m++)
          byte b;
          //Allows spaces to work correctly
          if(message[i+1] == ' ') {
            b = letters[message[i] - 'A'][m] << j | letters[26][m] >> (8-j);
          else if(message[i] == ' ') {
            b = letters[26][m] << j | letters[message[i +1] - 'A'][m] >> (8-j);
          }else {
            b = letters[message[i] - 'A'][m] << j | letters[message[i+1] - 'A'][m] >> (8-j);
          clrData();
          shiftOut(rData, rClock, LSBFIRST, bit(m));
          shiftOut(cData, cClock, LSBFIRST, b);
          delay(1);
PaulRB
#17
Sep 12, 2017, 09:02 pm Last Edit: Sep 12, 2017, 09:04 pm by PaulRB
Yes, I see what you mean about spaces and I did not think of that. The ASCII code for a space is 32, so when you subtract the code for an 'A', 65, the answer is negative. But then it gets assigned to a byte, which is  an unsigned type, so we get some value over 220, which is outside the bounds of the 'letter' array. Well done for spoting that and for figuring out a solution. Your solution could have been simpler, because
Code: [Select]
will always be zero for any value of m or j, so you might as well delete those parts of the formula.
What I don't understand is that you say that space takes too long to scroll. Are you saying it takes longer than any other letter? I think it should take the same time as any other letter, and that sounds ok to me.
cabyambo
Thanks for that way to simplify the space code. The problem I am having is that though the space works correctly, I personally think it is too long. I was wondering if there was a way to make the space 6 pixels wide instead of 8, or any width I'd like.
PaulRB
Not easily. You would then have the situation where 3 characters would be partially visible on the matrix instead of two: the space and the letter before and the letter after.
What if you just increase the overall scroll speed for the message? Find a balance where you can still read the message but the space scrolling does not seem so slow.
