if i move it over to another pin for the tlc5940, wont i have to edit the library or something like that to accommodate for a change like that?
Yes.
Yes.
so i just looked through all of the library files and i cant seem to find where to change the BLANK pin number, unless i'm missing somewhere simple...
The library may not change that pin. I am not familiar with the TLC5940, but I am familiar with the ethernet shield, and what will interfere with it. D10 should not be used by any other device. Don't use D4 either, unless you never plan on using a SD card in the shield slot. That is the slave select for the SD card.
so is it out of the question to choose a different pin than D10 for the ethernet slave select?
Not out of the question. I don't do it, but I have seen posts on the forum where it has been done.
If there is no mention of the BLANK pin, you might try disconnecting that connection from the Arduino. Don't connect the TLC5940 to D10.
Do you know which pin is the SPI slave select for the TLC5940? You will need to know that to initialize the SPI devices.
never mind on changing the ethernet slave select as this seems to be somewhat hardwired through the shield and anything different would have to be connected through wires aka not connecting the shield directly to the top of the arduino.
so i guess i will have to figure out how to change the BLANK pin for use by the TLC5940. According to the playground reference on arduino.cc:
BLANK: this marks the end of a PWM cycle in addition to blanking the output. We will reprogram TIMER1 to generate this signal. That will cost us the native PWMs on digital 9 and digital 10. (Tie a real, physical pull-up resistor on this line to keep things blanked while your Arduino boots. Depending on your hardware, it is possible that the TLC5940 would come up in a configuration that would dissipate too much power.)
So theoretically it should be as simple as finding another timer to use on the arduino
And this is not possible as the TLC5940 library needs Timer1 and Timer2 to drive the different pins as well as the millis() function which depends on Timer0 being used for it's functionality. But you can use the TLC5940 and the Ethernet shield together if you use another SS pin for the Ethernet shield (you have to modify the shield for that). The only requirement of the shield is that pin 10 is configured as an output and this is the case with the TLC5940 library.
If you want to have it easier, go with an Arduino Mega2560, you have more timer available and more PWM pins, so pin 10 is free for the Ethernet shield.
Im actually going to be using the mega1280 which as i understand, has timers on 5,6,9,11,46.(and timer0 but im not using that)
But i am already using 46 to drive an infrared led as a universal remote (IRremote Library)
TLC and ethernet share pins, 13,11 and 10. 13 and 11 are ok but 10 needs to be changed for the ethernet, and this should be relatively easily done in the library? And tlc absolutely needs 9 and 3 as timer outputs.
This summarizes what we have been discussing right? Is everything correct I hope. I really should stop working on this and study for my microwave active circuits class, haha oh well
and i was looking more at the library pinout code for the tlc and for the mega it still wants to use pin 10 so wouldn't there still be a problem and conflict with the ethernet shield?
On the Mega pin 10 is not used by the TLC5940 library. Look at Arduino_Mega.h. BLANK is on pin 12 not 10.
okay i see that but now however i see that the tlc uses pin 10 for XERR but i guess that usually disconnected so this won't be a problem i assume?
So this is the summary of how things should be connected for Ethernet and TLC:
50: tlc (VPRG)
10: tlc(XERR),ethernet(SS)
51: tlc(SIN)
52: tlc(SCLK)
51: tlc(MOSI)
52: tlc(SCK)
53: tlc(SS)
11: tlc(XLAT)
12: tlc(BLANK)
9: tlc(GSCLK)
46: IRled
So everything should be working with this setup then?
XERR doesn't need to be connected. If you want to connect it, use another pin than 10 and define the corresponding port and bit number in tlc_config.h. XERR must not be connected to pin 10 because pin 10 is an output and XERR on the TLC is an output too, so you produce a short circuit if you connect it that way.
You know that you have two pins twice in your list, don't you?
You may have to save the SPI registers between calls to the Ethernet library and the TLC library.
yeah i guess i do, i just double checked, its like that in the Arduino_Mega parameters in the tlc library
what do you mean by this?
A bit (unusable without modification) code to illustrate what I mean:
byte saved_spcr = 0;
byte saved_spsr = 0;
byte tlc_spcr = 0;
byte tlc_spsr = 0;
Ethernet.begin(...);
saved_spcr = SPCR;
saved_spsr = SPSR;
Tlc.init(...);
tlc_spcr = SPCR;
tlc_spsr = SPSR;
SPCR = saved_spcr;
SPSR = saved_spsr;
Ethernet.anyCall(...);
SPCR = tlc_spcr;
SPSR = tlc_spsr;
Tlc.anyCall(...);
im not really sure what any of that is doing.
but i recently hooked up the tlc to the ethernet shield + mega like this:
50: tlc (VPRG) (actually went to gnd)
10: tlc(XERR) (not this)
51: tlc(SIN)
52: tlc(SCLK)
51: tlc(MOSI)
52: tlc(SCK)
53: tlc(SS)
11: tlc(XLAT)
12: tlc(BLANK)
9: tlc(GSCLK)
46: IRled
and nothing attached to the tlc was working. so maybe it is necessary to add some form of register call stuff or whatever that is
I explicitly told you that you must not connect pin 10 to XERR, I hope your "not this" means you haven't made that connection. Why is it still in the list?
In your list you still have two pins listed twice so my belief in that being the actual wiring is a bit lowered.
On which pin is SS located on your TLC?
Have you tried this configuration without the Ethernet shield? Does it work? What code are you using for your tests?
first off, I' d like to say thanks for helping me through this as this is my first time really dealing with SPI. so THANKS!
i did not connect pin 10 to XERR for the reasons you mentioned before.
i have the tlc connected as such:
52: SCLK (25TLC)
51: SIN(26TLC)
12: BLANK(23TLC)
11: XLAT(24TLC)
9: GSCLK(18TLC)
per the BasicUse.pde with pinouts for Mega from library file
yeah im not sure which actually. i guess according to my list in my other post, i guess it should be 53 but im not sure if i actually have it connected, ill have to check when i get home.
I have not tried it without the ethernet shield, as the mega gets commands over udp. i can however send similar commands via serial so i will have to try that as well when i get home.
The code used is the code listed in like the third posting or so. It's kind of long so I won't post it again.
Again, thank you very much!
I wrote that because there is no SS pin on the TLC but you had it in the list of connections.
That may be a problem because writing to the Ethernet shield may interfere with the TLC as it will be listening too. I had the same problem with a WS2801 LED strip being controlled by the SPI hardware (for speed reasons) together with an Ethernet shield. I solved it by creating an SS: I interrupted the SCLK line and inserted a transistor which was controlled by the new SS pin. As long as the TLC doesn't get a clock signal it's not expecting any data to be received on the MOSI line.
thanks for the idea. but it seems i might not have to do that, as the tlc seems to be working fine now with the ethernet shield receiving udp packets as commands.
but just for knowledge, could you elaborate a little more on how you would connect the transistor for the SS stuff?
