today i received this sound modules i ordered on ebay hong kong, they should accept serial commands as confirmed by the seller. What i don't understand is the version i got. On the ebay auction it was showed the "V1.4" and the description says "DC2.5 ~ 4.5V"
Now this board shows "V1.5 / 2012.01.12", and "5v / 3.3v"
that means i can power it via arduino 5v?
someone have the right datasheet for this version? i have found this one but it's outdated.
I sent an email to the seller, waiting the response.
I said mini cause eBay listing says mini. In the other hand, we are in the same boat. If I am lucky today, will be able to get a 1gb micro card to test the board tonight. Keep you posted.
plugged everything and nothing. Just the led blinking twice and later, just keeps on. I assume that he is not reading the card cause I erased everything from the sd card and still doing the same.
mine is not working too
maybe i connected it wrong to the arduino or maybe it doesnt support 5volts or maybe the skecth i used was wrong, or maybe the files must be mp3. There are very few informations on this module combined with arduino.
i used this scheme (except for the 5v power) to connect it to analog A3 A4 A5arduino pins
Tried mp3 control mode, as I told you via pm and did not work cause the module is hardwired to work 2 serial line mode. I am also using "kingstone" micro sd card brand. I am pretty sure they are fake, but vendor told me that any brand will be fine.
