So, i am trying to figure out how to make two LEDs communicate with each other. More specifically, when one LED(1) is turned on, the other LED(2) will turn on, and when the LED(1) shuts off, the other LED(2) will also turn off.
// ARDUINO
//TOUCH SENSING BETA - LED TURNS ON WHEN LIGHT IS PRESENT
//BY: RICARDO DE LEMOS 1/17/2007
int led1 = 13;
int cath = 2; // negative
int ando = 3; // positive
pinMode(led1, OUTPUT);
pinMode(cath, OUTPUT);
pinMode(ando, OUTPUT);
//REVERSE BIAS
digitalWrite(cath, HIGH);
digitalWrite(ando, LOW);
//CHARGE LED
delay(6);
//READ LED CAP
pinMode(ando, INPUT);
delay(6);
//WRITE TO LED
if (digitalRead(ando) == LOW)
digitalWrite(led1,HIGH);
digitalWrite(led1,LOW);
//RESET
And the translated version for Processing.
//Processing
//biblio
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
//variabler
int turnOnLED = 13;
int sensorP = 3;
int sensorN = 2;
//setups
void setup(){
size (500,500);
println(Arduino.list());
arduino = new Arduino(this, Arduino.list()[0], 9600);
arduino.pinMode(turnOnLED, Arduino.OUTPUT);
arduino.pinMode(sensorP, Arduino.OUTPUT);
arduino.pinMode(sensorN, Arduino.OUTPUT);
//drawing
void draw(){
//charging LED
arduino.digitalWrite(sensorN, Arduino.LOW);
arduino.digitalWrite(sensorP, Arduino.HIGH);
delay(6);
arduino.pinMode(sensorP, Arduino.INPUT);
if(arduino.digitalRead(sensorP) == Arduino.LOW){
background(255);
println((arduino.digitalRead(sensorP)));
println((arduino.digitalRead(sensorN)));
does this code look right?
also, is there any specific way of actually building this? Any links or suggestions would be very helpful
It may be that the "digitalWrite" and "pinMode" routines are taking too long, so you're missing the conditions you're looking for - you may have to resort to direct port manipulation.
I am tempted to just fix up the digital write somehow so that when the one LED on pin 13 is on and the other LED detects it, it will go on. I wish i was more code-savvy
Do you actually need to use the LED as a sensor and emitter. If not then use a normal photo sensor as LEDs while they will work are not at their most reliable doing this.
for this experiment I'm trying, yes i do want to use LEDs...I just want to see the many things i can do with this..
but anyways, in the code, i see there is Cathode and Anode, which i assume mean the anode and cathode of an LED? would it be possible if i manipulated those to do what i want?
i found something on youtube that reflects about the same idea of what i would like to do: Adam Greig - YouTube
my first goal would be to have the LED turn on whenever an accelerometer on the board is moved to a certain threshold.
i already made the code for it which i have here:
Memsic2125
Read the Memsic 2125 two-axis accelerometer. Converts the
pulses output by the 2125 into milli-g's (1/1000 of earth's
gravity) and prints them over the serial connection to the
computer.
The circuit:
* X output of accelerometer to digital pin 2
* Y output of accelerometer to digital pin 3
* +V of accelerometer to +5V
* GND of accelerometer to ground
http://www.arduino.cc/en/Tutorial/Memsic2125
created 6 Nov 2008
by David A. Mellis
modified 30 Jun 2009
by Tom Igoe
// these constants won't change:
const int xPin = 2; // X output of the accelerometer
const int yPin = 3; // Y output of the accelerometer
int LEDpin = 13; //LED connected to digital pin 13
int thresholdx= 100;
int thresholdy= 100;
// variables to read the pulse widths:
int pulseX, pulseY;
// variables to contain the resulting accelerations
int accelerationX, accelerationY;
// initialize serial communications:
// initialize the pins connected to the accelerometer
// as inputs:
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
pinMode(LEDpin, OUTPUT);
int pulseX, pulseY;
// read pulse from x- and y-axes:
pulseX = pulseIn(xPin,HIGH);
pulseY = pulseIn(yPin,HIGH);
// convert the pulse width into acceleration
// accelerationX and accelerationY are in milli-g's:
// earth's gravity is 1000 milli-g's, or 1g.
accelerationX = ((pulseX / 10) - 500) * 8;
accelerationY = ((pulseY / 10) - 500) * 8;
if (accelerationX >thresholdx)
digitalWrite(LEDpin, HIGH);
else digitalWrite(LEDpin, LOW);
if (accelerationY > thresholdy)
// print the acceleration
Serial.print(accelerationX);
// print a tab character:
Serial.print("\t");
Serial.print(accelerationY);
Serial.println();
delay(100);
