Topic: how to receive two data in python [solved] (Read 1 time) previous topic - next topic
70agiuseppe
Feb 10, 2014, 10:51 am Last Edit: Feb 11, 2014, 05:00 pm by 70agiuseppe Reason: 1
my first exercise with python
   arduino sketch:
Code: [Select]
float t =  dht.readTemperature();
float h = dht.readHumidity()
bridge.put("temp", t);
bridge.put("umidi", h);
   I would like a very simple python example
Code: [Select]
 #!/usr/bin/python
      thank you very much
Robin2
Have you tried Googling "arduino python" and what did you find that might be useful?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
sonnyyu
To receive parameters in python you could use sys.argv, use print sys.argv find out how.
At Arduino sketch side:
Code: [Select]
void insertdb() {
  Process p;
  p.begin("/mnt/sda1/mysql.py");
  p.addParameter("1");
  p.addParameter("32");
  p.run();
http://forum.arduino.cc/index.php?topic=214431.msg1570756#msg1570756
70agiuseppe
thanks for the suggestions!
I'd like to see an example like:
Code: [Select]
$test= $client->get("temp");
echo $test;
but if it is possible written in python
70agiuseppe
Fortunately, I found a running system:
Code: [Select]
#!/usr/bin/python
import sys
sys.path.insert(0, '/usr/lib/python2.7/bridge/')
from bridgeclient import BridgeClient as bridgeclient
value = bridgeclient()
temperatura =  value.get('temp')
umidita = value.get('umi')
print temperatura
print umidita
I hope it will be useful
