Topic: standalone atmega 8 (Read 346 times) previous topic - next topic
ayush_khemkar
Hello, Iam using freeduino having at-mega 8l, I want to program other at-mega 8(at-mega 8A) ic on breadboard using freeduino as isp.
I have tried procedure of arduino on breadboard but it is not working.
What should I do?
BJHenry
Post a photo and schematic of your wiring, and exactly what error you're getting.
ayush_khemkar
#2
Oct 17, 2017, 08:41 am Last Edit: Oct 17, 2017, 09:32 am by ayush_khemkar
Schematic is given in the link below.
https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
I can't upload bootloader after uploading ArduinoISP program.
Error while burning bootloader.(given below)
Arduino: 1.8.5 (Windows 7), Board: "Arduino NG or older, ATmega8"
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
BJHenry
That error is almost always caused by incorrect wiring or wrong/missing clock source. double-check your wiring and make sure the crystal or resonator is hooked up correctly. Also, there should be 100nF caps on the supply pins for the microcontroller- they are missing from the tutorial but can have a major affect on the behaviour of the micro.
If you post a photo of your setup it would be helpful, as would be the verbose error message.
ayush_khemkar
Thank you, it worked.Problem was same as what u were saying.
lose connection.
thanks for assistance.
