First the setup:
- Stepper motor: NEMA-17 Bipolar 99.51:1 Planetary Gearbox Stepper - 3319_1 at Phidgets
- Pololu DRV8825 high current stepper driver: Pololu - DRV8825 Stepper Motor Driver Carrier, High Current (md20a)
- Stepper motor to DRV8825 wires: B2 (blue), B1 (red), A1 (black), A2 (green)
- 12 V Lipo battery pack
This setup works fine for very slow rotations. The maximum RPM I achieve with this is around 0.7 RPM. But I want to rotate the motor faster to certain positions from where it then should then rotate very slowly.
I already tried to double the input voltage using 2 lipo packs in serial and changing the potentiometer on the DRV8825 board. At a certain point on the potentiometer the motor begins to stutter until it finaly completely stops (probably the DRV8825 overheats).
How can I increase the motor speed? What alternative driver could I use which is controlable by Arduino which allows more current.
#define motorSteps 200
Stepper myStepper(motorSteps, pinStep, pinDir);
myStepper.setSpeed(300); // maximum working speed
myStepper.step(1000L);
Regards,
