Topic: Converting from AVR-GCC to Arduino (Read 517 times) previous topic - next topic
Dancopy
May 16, 2018, 11:36 pm Last Edit: Jun 02, 2018, 10:25 pm by surbyte Reason: Add code tags
First, my conversations can cause errors because I do not speak English, I use Google Translator.
The subject is this: I have a code made for LED Matrix HUB08 Protocol (https://www.youtube.com/watch?v=-XuD8idesZo) but, it is for AVR-GCC and I would like to use this code in Arduino. I believe that for those who understand the subject, be easy; could anyone, by great kindness, help me and convert (if that word) this code to use in Arduino?
The code "main.c" is in the link (youtube above) but I leave here:
Code: [Select]
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include <util/delay.h>
#include "pins.h"
#include "matrix.h"
#include "rtc.h"
#include "fonts.h"
static char *mkNumberString(int16_t value, uint8_t width, uint8_t prec, uint8_t lead)
 static char strbuf[8];
 uint8_t sign = lead;
 int8_t pos;
 if (value < 0) {
   sign = '-';
   value = -value;
 // Clear buffer and go to it's tail
 for (pos = 0; pos < width + prec; pos++)
   strbuf[pos] = lead;
 strbuf[pos--] = '\0';
 // Fill buffer from right to left
 while (value > 0 || pos > width - 2) {
   if (prec && (width - pos - 1 == 0))
     strbuf[pos--] = '.';
   strbuf[pos] = value % 10 + 0x30;
   pos--;
   value /= 10;
 if (pos >= 0)
   strbuf[pos] = sign;
 return strbuf;
int main(void)
 matrixInit();
 sei();
 matrixSetBr(4);
 matrixSetFont(font_matrix_16, 1);
 matrixLoadOutString("Large  ");
 matrixShow(ROW_BOTH, EFFECT_SCROLL_UP);
 DDR(BUZZER) |= BUZZER_LINE;
 PORT(BUZZER) &= ~BUZZER_LINE;
 _delay_ms(50);
 PORT(BUZZER) |= BUZZER_LINE;
 matrixClear(ROW_BOTH, EFFECT_NONE);
 while (1) {
   rtcReadTime();
   matrixSetCol(0, ROW_BOTH);
   matrixLoadOutString(mkNumberString(rtc.hour, 2, 0, '0'));
   matrixLoadOutString(":");
   matrixLoadOutString(mkNumberString(rtc.min, 2, 0, '0'));
   matrixSetFont(font_matrix_08, 1);
   matrixSetCol(55, ROW_TOP);
   matrixLoadOutString(mkNumberString(rtc.sec, 2, 0, '0'));
   matrixSetCol(55, ROW_BOTTOM);
   matrixLoadOutString(mkNumberString(rtc.date, 2, 0, '0'));
   matrixShow(ROW_BOTH, EFFECT_NONE);
 while (1) {
   matrixClear(ROW_BOTH, EFFECT_SCROLL_DOWN);
   matrixSetCol(0, ROW_TOP);
   matrixLoadOutString("Top");
   matrixSetCol(9, ROW_BOTTOM);
   matrixLoadOutString("Low");
   matrixSetCol(30, ROW_BOTH);
   matrixLoadOutString("Big");
   _delay_ms(1000);
   matrixLoadScrollString(" Scroll");
   matrixLoadScrollString(" large font");
   matrixScroll(SCROLL_START, ROW_BOTH);
   _delay_ms(3000);
   _delay_ms(1000);
   matrixLoadScrollString("Scroll");
   matrixLoadScrollString(" top line");
   matrixScroll(SCROLL_START, ROW_TOP);
   matrixSetCol(0, ROW_BOTTOM);
   matrixLoadOutString("Small");
   matrixLoadOutString(" font");
   _delay_ms(1000);
   matrixShow(ROW_BOTTOM, EFFECT_SCROLL_UP);
   _delay_ms(1000);
   matrixLoadScrollString(" bottom line");
   matrixScroll(SCROLL_START, ROW_BOTTOM);
   _delay_ms(1000);
   matrixShow(ROW_TOP, EFFECT_SCROLL_DOWN);
   _delay_ms(1000);
 return 0;
My thanks to everyone
bubulindo
Que lingua falas??
Este pedaço de código:
Code: [Select]
  while (1) {
    _delay_ms(1000);
    _delay_ms(3000);
    _delay_ms(1000);
    _delay_ms(1000);
    _delay_ms(1000);
    _delay_ms(1000);
    _delay_ms(1000);
nunca corre...
This... is a hobby.
Dancopy
Oi bubulindo! Falo o Português Brasil! certamente, como vc!! rsrsrs...  Achei q este fórum fosse somente Inglês!
Aliás, não tinha percebido em cima, no cabeçalho: Arduino Forum > International > Portugues
Então, o que vc me diz deste código? Quem sabe te interessa tb?
Até mesmo, baixei o Atmel Studio 7.0 e tentei carregar este código no mesmo mas, não soube fazer direito; quase deu certo mas, acho q faltou o quase!!
Li em vários lugares/sites sobre como abrir e/ou converter esse tipo de arquivo e alguns citam o Atmel Studio como aqui: https://electronicayprogramacionparatodos.wordpress.com/2017/12/29/programar-arduino-uno-en-c-con-atmel-studio/ e aqui: https://www.embarcados.com.br/atmel-studio/
O que eu quero é fazer do jeito mais fácil: abrir e gravar o código com o Atmel Studio ou adaptar o código no Arduino. Aprecio sua ajuda,
De onde vc é?
Abçs
Daniel
bubulindo
Eu falo Português... de Portugal.
De onde tiraste esse código? Foste tu que o escreveste?
Porque queres converter para o Arduino, se o código funciona, certamente que pode ser carregado para um Arduino sem passar pela IDE e linguagem do Arduino.
Mas adiante... depois de copiares as bibliotecas usadas nesse código para o Arduino (podes procurar isso online), só tens de copiar isso para um sketch do Arduino.
A função main() é dividida em duas partes. O código antes do while(1), metes na função setup() e o que estiver dentro do while(1) vai para dentro da função loop().
This... is a hobby.
Dancopy
Oi bubulindo! Primeiramente, obrigado por me responder.
Ñ fui eu que escrevi o código, o mesmo tirei daqui: https://www.youtube.com/watch?v=-XuD8ideQZo
Sim, certamente funciona mas, quero converter para o Arduino porque, segundo o autor, foi feito para AVR-GCC e eu não sei como abrir e gravar no Arduino ou no ATmega328P. Já tentei abrir com o Atmel Studio 7.0 mas não consegui os passos corretos; não sei se realmente pode ser aberto nesse programa.
Tentarei fazer como você falou mas, não sei se irei conseguir... depois lhe deixo saber;
Todas essas bibliotecas, coloco em pastas separadas, dentro da pasta libraries do Arduino?
#include <avr/io.h>
#include "pins.h"
#include "matrix.h"
#include "rtc.h"
#include "fonts.h"
E os textos após as bibliotecas, antes de void setup() deixo como está?
static char ...
return strbuf;
Se você quiser, dê uma olhada aqui para ver os arquivos: https://github.com/WiseLord/hub08lib
Obrigado++
bubulindo
Esses arquivos são de quê? Das bibliotecas? De onde copiaste o código?
Estas:
Code: [Select]
#include "pins.h"
#include "matrix.h"
#include "rtc.h"
#include "fonts.h"
são as bibliotecas que tens de copiar.
Sim, o código fora da função main() tem de ser passado para o arduino também.
This... is a hobby.
Dancopy
Oi bubulindo, o código tirei daqui: https://github.com/WiseLord/hub08lib
Se você se interessar em adaptá-lo ao Arduino, por favor, me envie!  Obrigado
