Topic: RGB NeoPixel ESP8266 Help!( (Read 445 times) previous topic - next topic
JoMik
There is Homeridge sketch. I want to add to it the "smoothness of switching" colors. Now, when the color / percent of the glow changes, it all somehow jerks (not smooth).
It seems like it can be implemented via FadeSpeed, I don't know exactly..
Help  :smiley-roll-sweat:
Code: [Select]
#include <ESP8266WiFi.h>
#include <math.h>
// Which pin On which pin is the ESP8266-12E connected to the NeoPixels
#define PIN 4
// How many NeoPixels are attached to the ESP8266-12E
#define NUMPIXELS      8
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(8, PIN, NEO_GRB + NEO_KHZ800);
WiFiServer server(80); //Set server port
String readString;           //String to hold incoming request
String hexString = "000000"; //Define inititial color here (hex value)
int state;
int r;
int g;
int b;
float R;
float G;
float B;
int x;
int V;
const char* ssid = "***";
const char* password = "***";
IPAddress ip(192,168,1,110);      // set a fixed IP for the NodeMCU
IPAddress gateway(192,168,1,1);  // Your router IP
IPAddress subnet(255,255,255,0); // Subnet mask
void WiFiStart() {
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  WiFi.config(ip, gateway, subnet);
    delay(100);
    Serial.print("_");
  Serial.println("Done");
  Serial.print("IP address: ");
  Serial.println("");
  server.begin();
void allOff() {
  for(int i=0;i<8;i++)
  strip.setPixelColor(i, 0, 0, 0);
  strip.show();
//Write requested hex-color to the pins
void setHex() {
  state = 1;
  long number = (long) strtol( &hexString[0], NULL, 16);
  r = number >> 16;
  g = number >> 8 & 0xFF;
  b = number & 0xFF;
  strip.setPixelColor (i, r, g, b);
  strip.show();
//Compute current brightness value
void getV() {
  R = roundf(r/2.55);
  G = roundf(g/2.55);
  B = roundf(b/2.55);
  x = _max(R,G);
  V = _max(x, B);
  strip.setBrightness(V);
  strip.show();
//For serial debugging only
void showValues() {
  Serial.print("Status on/off: ");
  Serial.println(state);
  Serial.print("RGB color: ");
  Serial.print(r);
  Serial.print(".");
  Serial.print(g);
  Serial.print(".");
  Serial.println(b);
  Serial.print("Hex color: ");
  Serial.println(hexString);
  getV();
  Serial.print("Brightness: ");
  Serial.println(V);
  Serial.println("");
void setup(){
  setHex(); //Set initial color after booting. Value defined above
  WiFi.mode(WIFI_STA);
  WiFiStart();
  showValues(); //Uncomment for serial output
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  //Reconnect on lost WiFi connection
  if (WiFi.status() != WL_CONNECTED) {
    WiFiStart();
  WiFiClient client = server.available();
  if (!client) {
    return;
  while(client.connected() && !client.available()) {
    delay(1);
  //Respond on certain Homebridge HTTP requests
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (readString.length() < 100) {
          readString += c;
        if (c == '\n') {
          Serial.print("Request: "); //Uncomment for serial output
          Serial.println(readString); //Uncomment for serial output
          //Send reponse
          client.println("Content-Type: text/html");
          client.println();
          //On
          if(readString.indexOf("on") >0) {
            setHex();
            showValues();
          //Off
          if(readString.indexOf("off") >0) {
            allOff();
            showValues();
          //Set color
          if(readString.indexOf("set") >0) {
            hexString = "";
            hexString = (readString.substring(9,15));
            setHex();
            showValues();
          //Status on/off
          if(readString.indexOf("status") >0) {
          client.println(state);
          //Status color (hex)
          if(readString.indexOf("color") >0) {
          client.println(hexString);
          //Status brightness (%)
          if(readString.indexOf("bright") >0) {
          getV();
          client.println(V);
          delay(1);
          client.stop();
          readString="";
PaulS
Code: [Select]
#define NUMPIXELS      8
What was the point of giving 8 a nice name when you never use the name?
Quote
What causes the color / brightness to change? The only thing that I can see that causes a change is input from a web client.
Quote
Pretend that we can not see what is happening. Because we can't. You need to do a MUCH better job of describing the problem.
Quote
What can? There is nothing in your code remotely like FadeSpeed, so this statement seems unlikely.
Code: [Select]
          readString += c;
Since you KNOW the maximum number of characters that you will deal with, there is NO point in pissing away resources using the String class to hold a known amount of data.
