Topic: Wall of Shame  (Read 38103 times) previous topic - next topic
larryd
No technical PMs.
The last thing you did is where you should start looking.
larryd
Oh my, what is the world coming to?
No technical PMs.
Boardburner2
Does your version of fritzing not have the sciency coiled wires ?  :)
MAS3
I was in panic for a moment, but then i found the source of the picture.
The end of this thread isn't close yet so all of us can keep on breathing.
I see some icky spots on the lower right breadboard, which may have something to do with abuse and/or mistakes made.
So i guess Paul got there through some learning process too.
But that is indeed what these breadboards are supposed to look like, certainly if you want to publish pictures of it.
So good job, Paul.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
Ricardol
I tried making something like this yesterday:)
Jiggy-Ninja
#155
Jun 04, 2017, 08:37 pm Last Edit: Jun 04, 2017, 08:37 pm by Jiggy-Ninja
This makes we wish I had taken a picture of the circuit I lashed up last weekend. I fit a potentiometer, two buttons, and an H-Bridge circuit onto a 170-point breadboard stuck to a protoshield and connected with the cheap jumper wires. It looked like velcro.
Well...if I did it once, I can do it again!
Can you believe I made no mistakes on the connections either time?
Hackaday: https://hackaday.io/MarkRD
Advanced C++ Techniques: https://forum.arduino.cc/index.php?topic=493075.0
larryd
I like the colours!   :)
No technical PMs.
Boardburner2
Oh My ,
What current are you using on you breadboard.
MAS3
Why doesn't this work when powered with 12 volts ?
(rhetoric question in this thread)
allanhurst
I hope there is a large puff of smoke and a burning smell
It deserves it
Allan
larryd
#160
Jun 10, 2017, 10:09 pm Last Edit: Jun 10, 2017, 10:09 pm by larryd
I think you have an infestation there:
No technical PMs.
Qdeathstar
So that's why by project wasn't working, damn bugs.. would have never have guess they'd be in the hardware.
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
ballscrewbob
Methinks it needs a haircut
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
travis_farmer
looks like maybe there was a roomba in there somewhere. glad i don't have to debug that :D
~Travis
My GitHub: https://github.com/travisfarmer?tab=repositories
My website is where i organize my thoughts and ideas. feel free to visit it (http://tjfserver.ddns.net/).
Arduino Talk Radio: http://travisfarmer.caster.fm/ (if i am on-air)
Robin2
When the wire at the top left succeeds in sneaking its way into the main socket things will be interesting.  :)
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
