You need a couple of capacitors on its output, say 0.1uF and 100uF in parallel. One takes out HF noise and the other LF noise. Within the current capabilities of the chip, the output voltage should be reasonably independent of the current draw, so it's probably the oscillation of the output that is giving you the "1 volt"
jack
