Topic: The data from GSM is processed by Arduino in a strange manner and incorrectly (Read 684 times) previous topic - next topic
alex12524
I am using Arduino uno and GSM SIM900A module for a simple electric switch board automation project. i am using IF statements for comparing the data received by GSM module. The GSM module is successfully configured for receiving sms.
When i send sms to my GSM, i am saving it in a int variable and then switching it to find a match through IF statements. The data sent by me is correctly displayed over the serial monitor but every time an incorrect IF statement is executed.
For eg:
If I am sending "1" as sms then the expected result would be Pin 12 high and "TV ON" displayed, but this doesn't happen instead of that I see Pin 8 as high and "LIGHT ON" displayed.
Similarly whatever data i sent it will always display result any thing other than the correct/expected output.
Following is the code I m working on, please suggest what might be the problem and how i can fix it.
Code: [Select]
#include <SoftwareSerial.h>
//use TX to 9 and RX to 11
SoftwareSerial mySerial(9,11);
  int ledTV = 12;
  int ledFAN = 7;
  int ledLIGHT = 8;
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  pinMode(ledTV,OUTPUT);
  pinMode(ledFAN,OUTPUT);
  pinMode(ledLIGHT,OUTPUT);
  ReceiveMessage();
 if (mySerial.available()>0)
   Serial.write(mySerial.read());
   storedata();
 void ReceiveMessage()
  mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
  delay(2000);
  mySerial.println("GSM SUCCESSFULLY CONFIGURED FOR RECEIVING");
void storedata()
  while(mySerial.available())
         int digit  = mySerial.read();
        if(digit=='1')
         digitalWrite(ledTV,1);    // making Pin 12 high if data received is '1'
         mySerial.println("TV ON"); // printing the same on the Serial monitor
         if(digit=='2')
        digitalWrite(ledFAN,1);
        mySerial.println("FAN ON");
        if(digit=='3')
          digitalWrite(ledLIGHT,1);
          mySerial.println("LIGHT ON");
          if(digit=='4')
            mySerial.println("ALL ON");
            if(digit=='5')
            digitalWrite(ledTV,0);
            digitalWrite(ledFAN,0);
            digitalWrite(ledLIGHT,0);
            mySerial.println("ALL OFF");
rw950431
Why start a new thread when its the same program as http://forum.arduino.cc/index.php?topic=460481.0 ?
You realise that your loop() function reads and prints one character from the GSM, then discards it, before sending the rest to storedata()?
alex12524
i don't know much of that.
can you tell me  how can i save an integer,and clear serial buffer each time when it executes program
alex12524
Please help me , I want to submit this project
