The problem with the original post is that the 3 variables - state, ledON, ledOFF - need to be in an array. The way you have it, each of the 3 pins are using the same variables, and it's messing things up. I put together a corrected version, and even tried it, so I know it works
long time = 0;
long timeON[14]; Â Â // I assume your pins go from 0-13
long timeOFF[14];
int state[14];
int i;
for(i=0;i<=13;i++) { Â Â Â Â Â //Edit: changed 14 to 13
 timeON[i] = 0;
 timeOFF[i] = 0;
 state[i] = LOW;
Serial.begin(38400);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
flashled(10, 1000, 500);
flashled(11, 500, 1000);
flashled(12, 500, 500);
void flashled(int ledpin, int ledON, int ledOFF) {
time = millis();
if (state[ledpin] == HIGH) {
 if (time >= timeOFF[ledpin]) {
  state[ledpin] = LOW;
  //Serial.print(ledpin);Serial.print(" ");Serial.println(state[ledpin]);
  digitalWrite(ledpin, state[ledpin]);
  timeON[ledpin] = timeOFF[ledpin] + ledOFF;
else {
 if (state[ledpin] == LOW){
  if (time >= timeON[ledpin]) {
   timeON[ledpin] = millis();    // you don't really need this line
   state[ledpin] = HIGH;
   timeOFF[ledpin] = timeON[ledpin] + ledON;
Good luck!
