When the ultrasonic sensor detects a wall it turns left and then when it detects another wall this time it turns right. How would you do that? Only one ultrasonic sensor.
Have a variable that you set whenever you make a turn. Look at that variable to see which way you turned last time and do the opposite.
Steve
What would that look like?
Use a variable to store the latest turn direction, then upon performing the turn change it to the other direction. As you have only two options, a boolean works just fine.
bool direction;
if (haveObstacle) {
if (direction == true) {
turnRight();
direction = false;
else {
turnLeft();
direction = true;
Not quite getting this. I understand the last part but how, and what do you you store in a variable?
Variables store a value. In this case the value true or false (basically 1 or 0).
