nevoz:
Hello All,Maurie has told me that his transmitter's codes are different from mine. So based on this, I suspect all transmitters have different codes. The first 4 sets of transitions are the same with our transmitters, but the next 4 sets aren't the same. (Every 4 transitions I have grouped into a "set" .. e.g. "1101 1111 0011" is 12 transitions group into 3 sets).
What this means is that if you are looking to duplicate your Kambrook transmitter's signal, you would need to sniff it first to find out what the code is. However, if you don't care what the Kambrook transmitter's code is, then you can simply use the codes in my arduino sketch and get your Kambrook GPO receivers to learn these signals. It just means you've rendered your Kambrook transmitter useless, which many wouldn't be too fussed about.
Thanks for the update - it would be significant for the WAF i think - as they may still like to reach for the physical remote sometimes !!
Craig
