Hi, i have custom pins_arduino that i would like to understand, can someone describe me this file ?
pins_arduino.h - Pin definition functions for Arduino
Part of Arduino - http://www.arduino.cc/
Copyright (c) 2007 David A. Mellis
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General
Public License along with this library; if not, write to the
Free Software Foundation, Inc., 59 Temple Place, Suite 330,
Boston, MA 02111-1307 USA
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
#define REPEAT8(x) x, x, x, x, x, x, x, x
#define BV0TO7 _BV(0), _BV(1), _BV(2), _BV(3), _BV(4), _BV(5), _BV(6), _BV(7)
#define BV7TO0 _BV(7), _BV(6), _BV(5), _BV(4), _BV(3), _BV(2), _BV(1), _BV(0)
#define NUM_DIGITAL_PINS 72
#define NUM_ANALOG_INPUTS 16
#define EXTERNAL_NUM_INTERRUPTS 48
#define analogInputToDigitalPin(p) ((p < 16) ? p : -1)
#define digitalPinHasPWM(p) (((p) >= 16 && (p) <= 21) || ((p) >= 24 && (p)<= 29) || ((p) >= 32 && (p)<= 37))
static const uint8_t SS = 20;
static const uint8_t MOSI = 21;
static const uint8_t MISO = 22;
static const uint8_t SCK = 23;
static const uint8_t SS1 = 28;
static const uint8_t MOSI1 = 29;
static const uint8_t MISO1 = 30;
static const uint8_t SCK1 = 31;
static const uint8_t SS2 = 36;
static const uint8_t MOSI2 = 37;
static const uint8_t MISO2 = 38;
static const uint8_t SCK2 = 39;
static const uint8_t SS3 = 44;
static const uint8_t MOSI3 = 45;
static const uint8_t MISO3 = 46;
static const uint8_t SCK3 = 47;
static const uint8_t SDA = 16;
static const uint8_t SCL = 17;
static const uint8_t LED_BUILTIN = 13;
static const uint8_t A0 = 0;
static const uint8_t A1 = 1;
static const uint8_t A2 = 2;
static const uint8_t A3 = 3;
static const uint8_t A4 = 4;
static const uint8_t A5 = 5;
static const uint8_t A6 = 6;
static const uint8_t A7 = 7;
static const uint8_t A8 = 8;
static const uint8_t A9 = 9;
static const uint8_t A10 = 10;
static const uint8_t A11 = 11;
static const uint8_t A12 = 12;
static const uint8_t A13 = 13;
static const uint8_t A14 = 14;
static const uint8_t A15 = 15;
#define Wire xmWireC
#define Wire1 xmWireD
#define Wire2 xmWireE
#define Wire3 xmWireF
#define digitalPinToPCICR(p) (((p) >= 0 && (p) <= 21) ? (&PCICR) : ((uint8_t *)0))
#define digitalPinToPCICRbit(p) (((p) <= 7) ? 2 : (((p) <= 13) ? 0 : 1))
#define digitalPinToPCMSK(p) (((p) <= 7) ? (&PCMSK2) : (((p) <= 13) ? (&PCMSK0) : (((p) <= 21) ? (&PCMSK1) : ((uint8_t *)0))))
#define digitalPinToPCMSKbit(p) (((p) <= 7) ? (p) : (((p) <= 13) ? ((p) - 8) : ((p) - 14)))
#ifdef ARDUINO_MAIN
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_PGM[] = {
NOT_A_PORT,
(uint16_t) &PORTA,
(uint16_t) &PORTB,
(uint16_t) &PORTC,
(uint16_t) &PORTD,
(uint16_t) &PORTE,
(uint16_t) &PORTF,
(uint16_t) &PORTH,
(uint16_t) &PORTJ,
(uint16_t) &PORTK,
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
// PORTLIST
REPEAT8(PA), // Header
REPEAT8(PB), // Pot and Speaker
REPEAT8(PC), // USARTC0 connected to USB on 2&3
REPEAT8(PD), // Header
REPEAT8(PE), // LEDs
REPEAT8(PF), // Switches
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
BV0TO7, // PORT A
BV0TO7, // PORT B
BV0TO7, // PORT C
BV0TO7, // PORT D
BV0TO7, // PORT E
BV0TO7, // PORT F
BV0TO7, // PORT H
BV0TO7, // PORT J
BV0TO7, // PORT K
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = {
REPEAT8(NOT_ON_TIMER), // PORT A Header
REPEAT8(NOT_ON_TIMER), // PORT B Pot and Speaker
REPEAT8(NOT_ON_TIMER), // PORT C USARTC0 to USB on 2&3
TIMER_D0A, // PORT D Header
TIMER_D0B,
TIMER_D0C,
TIMER_D0D,
TIMER_D1A,
TIMER_D1B,
NOT_ON_TIMER,
NOT_ON_TIMER,
TIMER_E0A, // PORT E LEDs
TIMER_E0B,
TIMER_E0C,
TIMER_E0D,
TIMER_E1A,
TIMER_E1B,
NOT_ON_TIMER,
NOT_ON_TIMER,
REPEAT8(NOT_ON_TIMER), // PORT F Switches
const TC0_t* PROGMEM timer_to_tc0_PGM[] = {
NULL,
&TCC0,
&TCC0,
&TCC0,
&TCC0,
NULL,
NULL,
&TCD0,
&TCD0,
&TCD0,
&TCD0,
NULL,
NULL,
&TCE0,
&TCE0,
&TCE0,
&TCE0,
NULL,
NULL,
const TC1_t* PROGMEM timer_to_tc1_PGM[] = {
NULL,
NULL,
NULL,
NULL,
NULL,
&TCC1,
&TCC1,
NULL,
NULL,
NULL,
NULL,
&TCD1,
&TCD1,
NULL,
NULL,
NULL,
NULL,
// TCE1 not defined on all xmegas
#if defined(PORTH)
&TCE1,
&TCE1,
#else
NULL,
NULL,
#endif
const uint8_t PROGMEM timer_to_channel_PGM[] = {
NOT_ON_TIMER,
0,
1,
2,
3,
0,
1,
0,
1,
2,
3,
0,
1,
0,
1,
2,
3,
0,
1,
const uint8_t PROGMEM adc_to_channel_PGM[] = {
0,
1,
2,
3,
4,
5,
6,
7,
8,
9,
10,
11,
12,
13,
14,
15
#endif
#endif
How can i know from this file what pin number is pointing for example to PORTE 1 pin ? Its file from xmegaduino, and i'am trying to blink a led, but defualt pin 13 is not mapped corectly i think
thanks for help and sorry for noobish questions
