My diy arduino 168 using the mini ,5V , 16Mhz external crystal . Will only upload if i use this command in avrdude ,
else i get the regular sync error.
I must use: -VVVV else it wont sync properly or something. I set the fuses correctly.
avrdude -P com3 -b 19200 -c avrisp -p m168 -vvvv -e -U flash:w:atmega168.hex -U lock:w:0x0F:m
Is there a way i can change the way arduino uses the avrdude command so it also uses -VVVV so i can upload via arduino ide ?
Back from school
I use the ATmegaBOOT_168_diecimila.hex from IDE 1.0 .
When i upload via FTDI it does 80% of the uploading but then it gets out os sync.
Uploading a sketch via AVRDUDE or bootloading only works if i do -VVVV else it will get the same error in avrdude.
