Arduino Forum
Using Arduino
General Electronics
multiplier
Print
Pages:
1
2
[3]
Topic: multiplier
(Read 9311 times)
previous topic
next topic
domo
Guest
Re: HV multiplier
#30
Apr 07, 2013, 04:36 pm
What i dont understand is, if there is a DAC, then hasnt the output become analogue? where does it turn dc again?
domo
Guest
Re: HV multiplier
#31
Apr 08, 2013, 04:15 pm
Last Edit
: Apr 14, 2013, 12:39 am by domo
Reason
: 1
When i connect up the circuit, it does not seem to work. I am inputting the output
dc42
Tesla Member
[add]
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
http://www.eschertech.com
Re: HV multiplier
#32
Apr 08, 2013, 04:30 pm
Which circuit have you built? I suggest you also post a photo of your wiring.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
domo
Guest
Re: HV multiplier
#33
Apr 08, 2013, 04:35 pm
Last Edit
: Apr 14, 2013, 12:38 am by domo
Reason
: 1
I have built the buffer without the transistor system and the external secondary voltage input.
dc42
Tesla Member
[add]
Re: HV multiplier
#34
Apr 08, 2013, 04:41 pm
If you build the circuit as I described it, then I will try to help you get it working. If you leave bits out, you're on your own.
domo
Guest
Re: HV multiplier
#35
Apr 09, 2013, 02:31 pm
Last Edit
Reason
: 1
photo1 just shows the wiring after op-amp and before HVM.
When i attempt to put in a second voltage input it doesn't work, therefore i tried to test the circuit by building whats on photo 2, which works but the output is not ideal.
Print
Pages:
1
2
[3]
Loading...
