OK, So what I think I understand:
You want motors to be able to act as a "winch" or "Crane", rolling a cable or string up, and rolling it back down again.
totally right i have the knowledge to create that, no problem i did it before.
So you need to be able to reverse the motors, right?
Jesssss! an up and down motion.
You have some windshield wiper motors but you do not want to use the back-and-forth movement, and you will remove that part??
the motors i have chosen have no back and forth movement in them. They move just in 1 direction all the time, only when i switch the wires it goes the other way.Just like a normal dc motor.
You will have to attach some "drum" or "Spool" to wind the cable on.
i already created the spool.
You need to know when the weight is at the top, and stop the motor.
yes i think this is able to program?
You need to know when the weight is at the bottom, and stop the motor.
right!
More questions:
?? How heavy is the weight the weight is about 1 kg
?? How long do you want it to take to go from bottom to top / not fast, just the top speed of the motor 80 rpm
OK, I see the Video and idea...
- So the weight does not need to stop at the bottom?? No this time it has to stop on his own! that's why i want to use the arduino and not the switch i used in the video.
Details! That's what Engineering is about i understand, you give me the questions that are relevant, very helpfull! thanks
