Topic: Neopixel Uhr  (Read 953 times) previous topic - next topic
Mickat1427
Dec 11, 2017, 08:32 pm Last Edit: Dec 11, 2017, 08:38 pm by Mickat1427
Hallo,
Mein Name ist Micha und ich bin 30 Jahre alt.
Ich beschäftige mich schon einige Zeit mit Arduino und würde gerne mit einem Wemos D1 mini eine Neopixel Uhr mit NTP Anfrage basteln und benutze folgenden Code :
Code: [Select]
#include <NtpClientLib.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
#define NUMPIXELS 60 // number of NeoPixel LEDs
#define PIN 2 // digital pin on ESP8266 for the NeoPixel data line
#define mirror_hands true // In case the NeoPixel ring is wired ant-clockwise.
byte hour_hand, minute_hand, second_hand, previous_second;
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
// clear all the leds to off
void clearHands() {
  for (byte i=0; i<=NUMPIXELS;i++) {
    pixels.setPixelColor(i,pixels.Color(0,0,0));
void drawHands(){
  clearHands();
  pixels.setPixelColor(hour_hand,pixels.Color(100,0,0));
  // if hour and minute are the same led, use a different color to show that
  if (hour_hand==minute_hand) {
    pixels.setPixelColor(minute_hand,pixels.Color(100,100,0));
    pixels.setPixelColor(minute_hand,pixels.Color(0,100,0));
  // draw the second LED, using medium brightness white
  pixels.setPixelColor(second_hand,pixels.Color(100,100,100));
  // show all the LED's, only the ones we have set with a color will be visible.
  pixels.show();
  // just a debug string, can be removed
  Serial.printf("hour:%d (%d), minute:%d second:%d (%d) \n",hour(),hour_hand,minute_hand,true_second,second_hand);
  WiFiManager wifiManager; // wifi configuration wizard
  wifiManager.autoConnect("NeoPixel_Clock", "secret"); // configuration for the access point, set your own secret.
  Serial.println("WiFi Client connected!)");
  NTP.begin("es.pool.ntp.org", -8, true); // get time from NTP server pool.
  NTP.setInterval(63);
  pixels.begin();
  pixels.setBrightness(254);
  byte hour_offset;
  minute_hand=minute();
  if (minute_hand>=10) {
    hour_offset=(minute_hand / 10)-1;
  }else
    hour_offset=0;
  if (hour() >= 12) {
    hour_hand = ((hour() - 12) * 5) + hour_offset;
  else {
    hour_hand = (hour() * 5) + hour_offset;
  if (mirror_hands) {
    hour_hand=60-hour_hand;
    minute_hand=60-minute_hand;
    second_hand=(60-second());
    if (second_hand==60) {
      second_hand=0;
    if (minute_hand==60) {
      minute_hand=0;
    if (hour_hand==60) {
      hour_hand=0;
    second_hand=second();
  if (second_hand!=previous_second) {
    previous_second=second_hand;
    drawHands();
Ich benutze ein 24er Neopixel Ring Clone.
Der Code läuft auch gut, allerdings ist er für ein 60er ring programmiert.
Ich würde gerne wissen wie man den Code ändern kann, das dieser auf mein 24er Ring richtig angezeigt wird.
Ich würde mich freuen wenn ihr mir helfen könntet.
Mit freundlichen Grüßen Micha.
Mickat1427
Danke für den Vorschlag.
Werde ich nachher mal testen wenn ich Zeit habe und werde dann Rückmeldung geben.
Mfg Micha
Mickat1427
#define NUMPIXELS 24 // number of NeoPixel LEDs
und probierst halt mal was passiert wenn
Code: [Select]
in
Code: [Select]
    hour_hand=24-hour_hand;
    minute_hand=24-minute_hand;
    second_hand=(24-second());
änderst.
Ich hab es mal getestet. Es fehlen immer noch 36 Sekunden.  Also er geht 24 Sekunden rum und dann ist dunkel und bei 0 Sekunden leuchtet er wieder.
Mickat1427
Wieder läuft der 60 LEDs ab statt 24...
Ich verstehe das nicht:(
Mickat1427
Ja das hab ich geändert ^^
Dennoch recht herzlichen Dank für deine mühe.
Der ring ist ja gegen den Uhrzeigersinn verkabelt. Aber der Sketch löst ja das problem.
MaHa76
Ich habe mal einen Code für eine solche Uhr selbst gebastelt, statt einen dieser abstrakten Vorlagen zu verwenden.
Als erstes mußt du dir überlegen, wie du die Stunden, Minuten und Sekunden umrechnen mußt, damit es dir entsprechend mit den 24 LEDs angezeigt werden kann.
Die Stunden hast du in 24h- Format vorliegen, willst sie aber wahrscheinlich in 12h Format anzeigen- da kannst du im ersten Schritt für alle Werte die größer als 12 sind einfach 12 abziehen.
Dann hast du noch alles auf deine 24- LEDs umrechnen, die Minuten und Sekunden springen also alle 2,5min/sek eine LED weiter, die Stunden alle 30min.
Das ganze kannst du in eine for- Schleife einbauen, wo du dann der jeweiligen LED eine Farbe zuordnen kannst.
nur mal sinngemäß:
Code: [Select]
for ( int i=0; 0<24; i++ )
        { if ( i == Sekunde/2.5 ) { leds[i] = CRGB(255,0,0); }
           if ( i == Minute/2.5 ) { leds[i] = CRGB(0,255,0); }
           if ( i == Stunde * 2 ) { leds[i] = CRGB(0,0,255); } }
agmue
#6
Dec 12, 2017, 06:13 pm Last Edit: Dec 13, 2017, 10:16 am by agmue
Anstelle ESP8266 nehme ich einen Nano mit millis() als Zeitbasis und Neopixel werden durch Dotstar (APA102) ersetzt. Dann ergibt sich aus vorangegangenen Anregungen folgender Testsketch:
Code: [Select]
#include <Adafruit_DotStar.h>
#include <SPI.h>         // COMMENT OUT THIS LINE FOR GEMMA OR TRINKET
#define NUMPIXELS 24 // Number of LEDs in strip
#define HELLIKKEIT 50
// 100 anstelle 1000 beschleunigt die Anzeige
#define TAUSEND 1000
// Hardware SPI is a little faster, but must be wired to specific pins
// (Arduino Uno = pin 11 for data, 13 for clock, other boards are different).
Adafruit_DotStar pixels = Adafruit_DotStar(NUMPIXELS, DOTSTAR_BRG);
uint32_t aktmillis;
void clearHands() {
  for (byte i = 0; i < NUMPIXELS; i++) {
    pixels.setPixelColor(i, pixels.Color(0, 0, 0));
void drawHands() {
  clearHands();
  pixels.setPixelColor(hour_hand, pixels.Color(HELLIKKEIT, 0, 0));
  if (hour_hand == minute_hand) {
    pixels.setPixelColor(minute_hand, pixels.Color(HELLIKKEIT, HELLIKKEIT, 0));
    pixels.setPixelColor(minute_hand, pixels.Color(0, HELLIKKEIT, 0));
  pixels.setPixelColor(second_hand, pixels.Color(HELLIKKEIT, HELLIKKEIT, HELLIKKEIT));
  pixels.show();
  char buf[70];
  snprintf(buf, sizeof(buf), "millis: %lu, hour:%d, minute:%d (%d), second:%d (%d)", aktmillis, hour_hand, minute(), minute_hand, second(), second_hand);
  Serial.println(buf); // print date and time
  pixels.begin();
  pixels.setBrightness(96);
  pixels.show();  // Turn all LEDs off ASAP
  aktmillis=millis();
  minute_hand = minute() / 2.5;
  if (hour() >= 12) {
    hour_hand = hour() - 12;
    hour_hand = hour();
  if (mirror_hands) {
    hour_hand = 23 - hour_hand;
    minute_hand = 23 - minute_hand;
    second_hand = (23 - second() / 2.5);
    if (second_hand == 24) {
      second_hand = 0;
    if (minute_hand == 24) {
      minute_hand = 0;
    if (hour_hand == 24) {
      hour_hand = 0;
    second_hand = second() / 2.5;
  if (second_hand != previous_second) {
    previous_second = second_hand;
    drawHands();
byte second() {
  return byte( aktmillis / TAUSEND % 60);
byte minute() {
  return byte( aktmillis / TAUSEND / 60 % 60);
byte hour() {
  return byte( aktmillis / TAUSEND / 60 / 60 % 24);
Die Division durch 2.5 ergibt ein etwas unruhiges Bewegungsverhalten, sonst scheint der Sketch aber zu funktionieren und ich hoffe, er hilft Dir.
postmaster-ino
Hi
Man kann ja alle 500ms (oder kürzer) die nächste LED hochdimmen und die Aktuelle dafür runter.
MfG
Mickat1427
Vielen Dank für die Hilfe von euch. Werde es mal testen und dann Bescheid geben.
Wäre es noch hilfreich ein Pegelwandler zwischen den Wemos und den Neopixel zu hängen ?
Mfg Micha
Tommy56
Da Du nur zum Neopixel schreibst, ist das unkritisch. Der Pegel wird als High erkannt.
Gruß Tommy
"Wer den schnellen Erfolg sucht, sollte nicht programmieren, sondern Holz hacken." (Quelle unbekannt)
Mickat1427
Genau am Wemos wird nur der Neopixel Ring betrieben.
Tommy56
Wenn NTP, dann sollte man den Pool der 4 de-Server nutzen, falls mal ein Server nicht da ist (habe ich schon gehabt).
Der Code ist beim Weihnachtsstern #476 verlinkt.
Gruß Tommy
Mickat1427
#12
Dec 13, 2017, 09:59 am Last Edit: Dec 13, 2017, 10:10 am by Mickat1427
Hallo,
habe mal den Sketch vom kulturbereicherer verwendet und ich muss sagen sie läuft!
Allerdings habe ich heute gesehen, das die Stunden Anzeige auch nicht ganz an ihrem Platz ist wo sie sein soll. Habe mal ein Foto angehangen.
Vielleicht hat jemand eine Idee wie man sie an ihrem Platz bekommt.
Mfg Micha
MaHa76
Wo ist sie denn und wo soll sie denn sein?
Mickat1427
Danke nochmal kulturbereicherer.
Werde noch ein bisschen basteln aber die Uhr läuft.
Wenn ich es fertig habe und es alles läuft wie es soll, stell ich den fertigen Sketch rein.
