How to replace the field type and value in dbgrid?
My SQL query:
Code: XML [Select] DBForm.DBquery.SQL.text:='select callstart, callend, origin, destination, direction from callrecord;
termtype are integer values 0...3, instead I would like to show in dbgrid column fields: None, Incoming, Outgoing or Internal, accordingly. These text values are not stored in any DB table to be joined with; it is also not allowed to add smth to this DB (in my case). Is there a way how to do this "on fly", when the dbgrid obtains the values from the DB?
Has this question something to do with an Arduino?
If so, post the Arduino program that contains the problem.
...R
