I have connected two sensors (MEAS) that sense vibrations to my Arduino Uno. I'm a real beginner on both programming and electronics but I have written a short code that allows me to get two different LED to lit up when I trigger the sensors (the LEDs are triggered separately by each sensor). However, I want to see which of the sensors that was triggered first, and my code just lit both of the LEDs. I would like to extend my code in some way so that once one of the sensors has been triggered the Arduino should not allow the other sensor to trigger (and vice versa). Does anybody knows how to extend my code so that becomes possible?
Here is the code, Cheers Martin
int analogPin0 = 0; // input for 1st vibration sensor (MEAS)
int analogPin5 = 5; // input for 2nd vibration sensor (MEAS)
int ledPin13 = 13; // LED connected to digital pin 13
int ledPin12 = 12; // LED connected to digital pin 12
int val0 = 0; // variable to store the value read
int val1 = 5;
int low = 10;
int high = 800;
{ //Serial.begin(9600); // setup serial, has to be stopped to allow LED to lit
pinMode(ledPin12, OUTPUT); // sets the pin as output
pinMode(analogPin0, INPUT); // sets the pin as input
pinMode(ledPin13, OUTPUT); // sets the pin as output
pinMode(analogPin5, INPUT); // sets the pin as input
val0 = analogRead(analogPin0); // read the input pin
Serial.println(val0); // debug value
val1 = analogRead(analogPin5); // read the input pin
Serial.println(val1); // debug value
if ( val0 > high ) {
digitalWrite(ledPin12, HIGH);
delay(500); //seems very important to get each sensor trigger only ONE LED
if (val1 > high) {
digitalWrite(ledPin13, HIGH);
delay(500); //seems very important to get each sensors trigger only ONE LED
analog pins are refered to as A0 A1 A2 etc
You do not need to set them to INPUT
removed comments
int analogPin0 = A0; // input for 1st vibration sensor (MEAS)
int analogPin5 = A5; // input for 2nd vibration sensor (MEAS)
int ledPin13 = 13;
int ledPin12 = 12;
int val1 = 5;
int high = 800;
int first = -1; // who was first is undecided
digitalWrite(ledPin12, LOW);
digitalWrite(ledPin13, LOW);
if (val0 > high && val1 < high)
first = 0;
Serial.println("0 was first");
if (val0 < high && val1 > high)
first = 1;
Serial.println("1 was first");
if (val0 > high && val1 > high)
first = 2;
Serial.println("equal .... retry");
if (first >= 0 )
first = -1;
delay(5000);
delay(3000);
Serial.println("GO!");
However, I would like the sensor that is triggered first to lit its LED and that the LED continuous to glow (and that the other sensor cannot be triggered). The reason is because I will use it in an application where I want to be able to judge (afterwards) which of the two sensors that was triggered first. I'm a biologist and interested in adaptive coloration in prey and I will use this little gadget to see which out of two offered prey types that wild birds will attack first.
