The weird thing is that, the LED lights up if i dont ground the ADJ pin, making the 470ohm useless. So the ADJ and vOUT pins are connected with teh 220 resistor, the LED is being fed by the vOut pin with 3.x volts (not sure how) and grounded.
I tried 2 LED's in series and the vOut pin cranks to 6volts wich seems correct but... should I be the one choosing the voltages?
MarkT:
That regulator has about 2.2V drop-out at 1.5A, so the greatest output voltage you can get from 5V input is 2.8V
Also you are missing decoupling capacitors - regulators in general need them to prevent oscillation.
He's good on drop-out, his source is 9VDC.
Decoupling caps would be highly recommended but the problem here is likely thermal shut down, no current limiting resistor is going to put this voltage regulator into shut down mode immediately as it's going to peg at 1.5 Amps.
Reconsider your power source. I recommend an LED driver made for this.
If you want you could run this beacon at 1.4A with a big heatsink on that voltage regulator, but you're going to need to modify your circuit.
Use a 12V Source again.
Run your output on that Voltage Regulator at 5V.
Throw a 5 Watt resistor value 1.2 Ohms in Series with your LED.
LEDs act as DEAD SHORTS, you have to pay attention to their specs on current and put a resistor in there after doing a little math related to LED forward voltage and Current Limiting Resistors.
Google these terms and you'll find a lot of information.
Isn't the center pin of a regulator normally connected to ground? At first glance I'd expect to see a wire going from the center of the regulator to the ground of the battery.
Also, I'm very curious, what program did you use to make these graphics? Fritzing?
ParallelLogic:
For a fixed voltage regulator the sense input is normally grounded, but its not a requirement even then, the regulator simply acts to keep the voltage difference between output and sense constant.
Ok so from what i've read in this topic, its probably Thermal shutdown and the vOut is constant 1.25v.
A heatsink wont help for long since the regulator is being hit by 2amps.
Since i want to connect 2 LED's in series, im guessing thats 2amps total but about 7 / 8volts due to voltage drop on the first LED being 3.6v.
To fix this i need a 5Watt 1.2 Ohms resistor in series with LED.
Guess i'll need to go to the electronics store before going home =)
The 5Watt 1.2ohm resistor is going to limit the current the LED is sucking so the Voltage Regulator wont shutdown due to thermal problems.
Is there a better way to do this? Drop 12v to 3.6v to feed a 3.6v 2amp LED?
I noticed that theres alot of heat being generated, wich means the circuit is being less efficient.
LED gets hot, Voltage regulator gets Hot, and probably the 5Watt 1.2Ohm resistor will get hot too.
Something came to my mind. If its the Thermal overload protection kicking in because of the 2Amps, maybe if i use a LM318 it will work fine.
LM318 handles up to 5Amps and that should avoid the thermal overload protection =)
Your problem starts right here with a common misconception. Unless it is a very unusual LED it does not 'pull' 3.6 v or 1Amp. You LED has an absolute maximum current rating and a nominal current rating. A current limiting resistor MUST (I would make this flash if I knew how) be used in series with the LED. The resulting forward voltage that appears across the LED is dependent on the current flowing through it, you can find typical values in the data sheet for the LED. Your LED has probably been saved from destruction by the fact that the regulator has been shutting down. If you substitute a regulator that does not shut down then you will be replacing the LED rather quickly.
Well, i replaced the LM317 with the LM338 and its working now.
However, has most of you said, the fact that im not using a current limiting resistor is probably killing the LED's (i have now 2 LED's in parallel).
I need to buy that resistor, i have nothing similar to that. 5W resistor is new to me =)
Each LED Absolut Maximum Current flow is 2.8AMPS.
This ones already have a Heatsink below them wich helps with the heat.
How could i limit the current to 2amps? how many ohms on that current limiting resistor? also, since i have 2 LED in parallel, 1 resistors for both is enough? or should i have 1 resistor for each LED?
You can't do that either (and expect them to survive). They don't work like resistors.
I mounted them on my motorcycle (it was the whole purpose since the beginning).
Everything seems to work fine however, as you said floresta, without current limitation these guys go nuts.
I added a heatsink to the voltage regulator but it gets really hot really fast, even faster supplied by the motorcycle battery. I try to keep them on only for a minute or two.
I need to fix this current problem. So far its a weak prototype.
How come i cant have the LED in parallel? wouldnt that share the amps between them and keep the voltage equal for both of them?
You must limit the current separately for each LED that means each one must have it's own resistor and then they, by definition, will not be in parallel.
The current is the dependent variable. Each LED will have it's own current determined by the supply voltage, the series resistance, and the particular characteristics of the particular LED. The current for both LEDs will be provided by your supply.
They are like snowflakes. No two are exactly the same and no two will have exactly the same forward voltage.
SgtOneill:
Oh boy... i must be torturing these LED
Just use the LM338 and build a Current Limiting Circuit with that. Driving LEDs with voltage can be frustrating (you are experiencing that right now). The key for success is driving them with current. Take a look at LM338's datasheet, you'll find the answer.
No they are not, the data sheet is sales talk, you need caps. Many beginners fall into this trap. Without caps on any regulator you will not get a stable output and you will continue to be driven nuts.
