Hello, my project consists of a 60 LED Strip, an RTC, and the HC-05 bluetooth module. My issue is that when I send the HC-05 simple commands such as single characters, I receive noisy output. I am using an Arduino UNO.
Example:
Input | Output | Percentage* |
a | No Output | 20% |
a | 97 | 50% |
a | 216 | 10% |
a | 251 | 5% |
a | 246 | 5% |
a | 255 | 10% |
*Approximate percentage of times I get the output (of 20 readings)
I believe the "No Output" readings can be attributed to the delay caused by the LED functions. That is fine. The issue is the inconsistent readings where 'a' produces a number other than the expected 97. Furthermore when I comment out the LED effects I get 100% accuracy with sending 'a' and receiving 97. My initial thought is that the power draw from the LED strip is messing with the voltages within the circuit. However, the module will still produce 100% accuracy when the LED's are powered and the code running their effects is commented out.
Please help me pinpoint what is causing the issue between the LED's and the Bluetooth module's output.
Below is my code:
#include <Wire.h>
#include <stdio.h>
#include <DS3231.h>
#include "FastLED.h"
#include <SoftwareSerial.h>
//LED Strip Data WS2812
#define LED_PIN 9
#define NUM_LEDS 60
#define CHIPSET WS2812
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS], l, seconds;
#define BRIGHTNESS 128
byte lastsecond;
// Clock Settings
boolean mode = 0, lastsec = 1;
int count = 0, effectMode = 0;
int redSecond = 10;
#define MAX_EFFECTS 4
// Create a DS3231 object. (Real Time Clock)
DS3231 rtc(SDA, SCL);
Time t;
// Bluetooth //
boolean debug = true;
SoftwareSerial BTserial(0, 1); // RX | TX
// max length of command is 20 chrs
const byte numChars = 20;
char receivedChars[numChars];
boolean newData = false;
char myChar ;
//fix IR from phone
//////////////////////////////// SETUP //////////////////////////////////////
delay(2000);
Wire.begin();
rtc.begin();
BTserial.begin(9600);
IRSensor.enableIRIn(); //Start IR Receivers
FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
//////////////////////////////// MAIN LOOP //////////////////////////////////
int rGreen = random(256), rRed = random(256), rBlue = random(256);
//Dims the clock after 9PM and before 6AM
t = rtc.getTime();
if (t.hour >= 21 || t.hour <= 6) LEDS.setBrightness(constrain(5, 0, 100));
else LEDS.setBrightness(constrain(128, 10, 255));
//********** Effects ************
if ( mode == 0) {
IRSensor.resume();
for ( int i = 0; i < 240; i++) {
BTInput();
//*******DIFFERENT IMPLEMENTED EFFECTS*****
switch (effectMode) {
case 0:
//printColors( rGreen, rRed, rBlue);
Glow( rGreen, rRed, rBlue);
break;
case 2:
Crazy(i);
break;
case 3:
Temperature();
break;
default: //turns clock off
mode = 1;
break;
//************ END EFFECTS **********
// Changes to Clock mode
if ( digitalRead(SENSOR_PIN) == 0 ) mode = 1;
if ( mode == 1) {
modeTransition();
break;
////////////////////////////////// EFFECTS //////////////////////////////////
void Glow( int rGreen, int rRed, int rBlue) {
for ( int j = 0; j < 60; j++) leds[j] = CRGB(rGreen, rRed, rBlue);
if (count < 121) LEDS.setBrightness(constrain(count, 0, 128));
else {
int x = map(count, 121, 239, 121, 0);
LEDS.setBrightness(constrain(x, 0, 128));
count++;
if (count > 239) count = 0;
ledShow(20);
//////////////////////////////// HELPER FUNCTIONS ///////////////////////////
void printColors(int g, int r, int b) {
Serial.println("Current Color Settings: (G,R,B)");
Serial.println(g);
Serial.println(r);
Serial.println(b);
void ledShow(int refresh) {
FastLED.show();
FastLED.delay(refresh);
////////////////////////////// BLUETOOTH FUNCTIONS //////////////////////////
void BTInput() {
if (BTserial.available() > 0) {
Serial.println(BTserial.read());
void BTInput2() {
while (BTserial.available() ) {
myChar = BTserial.read();
Serial.print(myChar);
while (Serial.available()) {
myChar = Serial.read();
BTserial.print(myChar);
void recvWithStartEndMarkers()
// function recvWithStartEndMarkers by Robin2 of the Arduino forums
// See http://forum.arduino.cc/index.php?topic=288234.0
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char endMarker = '>';
char rc;
rc = BTserial.read();
if (recvInProgress == true)
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void parseData()
newData = false;
if (debug) {
Serial.println( receivedChars );
if (receivedChars[0] == 'O' && receivedChars[1] == 'N' ) {
//Serial.println("on");
if (receivedChars[0] == 'O' && receivedChars[1] == 'F' ) {
//Serial.println("off");
Lastly, I am using my Samsung Galaxy S6 and a Bluetooth Terminal App to communicate with the Bluetooth module.
