I know that I can see free SRAM with the [u]MemoryFree[/u] library, but is there a way to determine the amount of PROGMEM (flash) memory used?
Yes the IDE tells me how large the code is, but I want to be able to determine it runtime. Is this possible?
I tried re-flashing the bootloader (which erases the whole chip except for the last 512 bytes), then used pgm_read_byte(address) running backwards to find the first non 0xFF byte (which works), but it seems like a clumsy way to do it (and the start point differs between 16K, 32K, 256K, etc... boards).
Krupski:
Is there a good way to do this?
I looked at a couple of disassemblies and the last thing symbol always seems to be a thing called "__stop_program".
It's two bytes long and is probably the "fini0" section mentioned here: Memory Sections
How do you think a bootloader puts a program in flash memory
By residing in the read-only boot segment of program memory.
Software elsewhere in memory cannot write to program memory, so if you want to use unused program memory to store data, you're going to have to write your own bootloader that handles those writes for you.
It can if you set the fuses appropriately...see section 26.5 of the datasheet.
In which case, the whole of memory is boot segment, the only place the SPR instruction can execute.
Using unused program memory at runtime is not really sensible:
I think what this section of the datasheet shows you can
26.5 Boot Loader Lock Bits
If no Boot Loader capability is needed, the entire Flash is available for application code. The
Boot Loader has two separate sets of Boot Lock bits which can be set independently. This gives
the user a unique flexibility to select different levels of protection.
The user can select:
• To protect the entire Flash from a software update by the MCU.
• To protect only the Boot Loader Flash section from a software update by the MCU.
• To protect only the Application Flash section from a software update by the MCU.
• Allow software update in the entire Flash.
See Table 26-2 and Table 26-3 for further details. The Boot Lock bits can be set in software and
in Serial or Parallel Programming mode, but they can be cleared by a Chip Erase command
only. The general Write Lock (Lock Bit mode 2) does not control the programming of the Flash
memory by SPM instruction. Similarly, the general Read/Write Lock (Lock Bit mode 1) does not
control reading nor writing by LPM/SPM, if it is attempted.
I can't see why any one would want to change the flash at run time, as it only has a life of a few 1000's of writes.
To the others: I want this piece of information because the program I am writing is for a research project (I'm not a student - I'm support staff). The professor wants one of the menu screens to display hardware stats like supply voltage from the wall wart, free SRAM, free FLASH and free EEPROM (as well as a few other things).
Don't ask me why... I don't know. I'm just doing what I'm told!
Anyway, I could have just hardcoded some numbers into the program and forgot about it, but I want to to it right... so that's why I asked!
(and yes I COULD actually use the flash memory runtime to store things like program settings (which I currently store in EEPROM) if, for example, the settings changed a LOT and I didn't want to wear out the EEPROM).
But, alas it's only for display purposes.
Thanks again all! Always get fast and great help here!
I just discovered that the stock MemoryFree function (to show free SRAM) does not work properly on a MEGA 2560 board (unless the board has over 32K of SRAM!)...
The "new" PROGMEM size function works perfectly, but the original FreeMemory() function does not.
