As you receive characters from the serial port, store them in a char array and null terminate it. Before you store, check for 'X' or 'Y'. if that's what you have, use the current first char in your array to tell you which value you've been accumulating. Then use atoi to parse the value associated with it using
val=atoi(&myArray[2]);
Store val in your X or X variable, whichever is appropriate
set your index variable for the array back to zero.
Thanks guys for all the replies! Sorry that i have to ask second time cause i didnt got it. I said it in another thread...i wanna learn but unfortunately im a newbee and sometimes it takes osme time to get the thing behind a operation
if (cmdByte >= 'A' && cmdByte <= 'Z'){
cmdByte |= 0X20; // Convert to lower case
The comment says it all? I convert all letters (A-Z) to lower case (a-z) so I don't have to check for either version.
I understand the method of Riva a bit but i dont get the line where i say "take everything after the letter and the :" is it the line with
The code snippet I posted is expecting a letter followed by a number e.g. t100m123 would assign 100 to triggerBits and 123 to triggerMask. Your code was sending X:163 Y:178 so you would need to read the first character (X/Y) to determine where the following number gets stored but you would also need to read over the : else parseInt would not work.
If instead of Serial.print("Z:"); Serial.println( JoyVarZ ); } you did Serial.print("Z"); Serial.println( JoyVarZ ); } instead you will remove the colon that seems to serves no purpose here. You don't even need to split values across lines as the code would work just as well with X163Y178Z193 as with
X163
Y178
Z193
okay great, the line wrap was only to get not totally confussed so i understand everything with the Serial.print() stuff.
i still didnt got the thing with the converting to lower case. i mean i could also send the letter as lower case like
Serial.print('a');
Sorry that im a little bit confused, but i really try to get it And my biggest questions: In which line i say that everything after the letter is a value?
Given that you control what's being sent from the XBEE, you can rely on the X,Y,Z being upper case - there should be no need (in this situation) to worry about whether they are.
Does this help a little better, I have altered it to suit your data (apart from the colon) and remove the code to convert upper case to lower case as your won't need it with data fed from a program. I needed it because the data was typed by humans so could be mixed upper/lower case.
void setup(){
void loop(){
int X,Y,Z = 0;
while (Serial.available() > 0){ // Serial available? Read it.
unsigned int cmdData;
byte cmdByte = Serial.read(); // Read command
switch(cmdByte) {
case 'X':
X = Serial.parseInt(); // Read X value
break;
case 'Y':
Y = Serial.parseInt(); // Read Y value
break;
case 'Z':
Z = Serial.parseInt(); // Read Z value
break;
default:
Serial.print("X = ");
Serial.print(X);
Serial.print(", Y = ");
Serial.print(Y);
Serial.print(", Z = ");
Serial.println(Z);
Serial.parseInt() will read serial bytes until a non number arrives and then convert what it's already got into an int.
then read about sscanf(). It is not always your friend, however. Because it can do so much, it is often an H-bomb-to-kill-an-ant approach chewing up more memory than some simplier alternatives.
