Topic: High-speed opto encoder (Read 304 times) previous topic - next topic
braev
Hi there,
I am successfully counting a linear opto encoder at low speed. One step is 4.23 mm and I want to move at around 1m/1s, so this makes 237 steps per second. Can Arduino handle that and can Interrupts be used?
Robin2
I have a small DC motor that uses an optical detector to produce a pulse every revolution. It has no trouble at 15000 RPM or 250 pulses per second. I reckon it could work a lot faster as that rate is only 1 pulse every 4000 microsecs
Yes, interrupts can be used and would probably be essential.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
braev
...R
thanks very much. I'll try it.
