Topic: Real Time processing MPU6050 readings with MATLAB (Read 487 times) previous topic - next topic
DHemalUOP
Sep 09, 2017, 08:17 pm Last Edit: Sep 09, 2017, 08:26 pm by DHemalUOP
I am expecting to real time analyze Gyro sensor(MPU6050) readings with Matlab. I cant use Arduino library of the sensor for MATLAB. I have 2 Arduino boards & attempted to get readings by connecting via RX TX ports. How can I read Gyro output signal in MATLAB??
Robin2
Why can't you use the sensor library?
The usual thing would be for the Arduino to get a value from the sensor and send it to the PC using some Serial.print() statements.
Please post your Arduino program.
And post your program using the code button </>
Code: [Select]
so it looks like this. See How to use the Forum
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
anilkunchalaece
You dont have to use the sensor library for MATLAB.
use the library in Arduino and send the data via USB cable to MATLAB
Check Arduino  Tutorials here
https://www.youtube.com/playlist?list=PLjzAdjfnefPzBOijmWo9t6-S2x2jye2fs
Kunchala Anil
Grumpy_Mike
Quote
Because teacher said he couldn't.
