I have the EEPROMex library installed. I will have to check to make sure it's in the right place or that it's named properly. Thanks.
So I found that the name of the library is EEPROMEx and as downloaded it was EEPROMex. So I changed the name in the code to the proper one but it still doesn't work. It says 'class EEPROMClass' has no member named 'readFloat'. This must be a library issue but unsure how to fix.
EDIT***
So I copied the files from github EEPROMBackupVar.h and EEPROMVar.h into the EEPROMEx folder and it worked after that. I had tried to add the EEPROM.h but I had to remove it to make it work.
So it seems to be functioning so far.
Andrew
