Dear All
I do not know if you still follow that topics but it look like it can help me to solve my similar problem.
I can not understand your explication may be because some missing knowledge.
I am actually puting in sleep mode my microcontroller with RTCZero library.
My module work as the following:
Each hour my Ardafruit Feather MO take the measure of 8 sensors. Whe it's done, it send the data and goes to sleep for about 59mn.
With RTCZero, my borad sleep 10 second, flash a led and sleep 10 second, flasha led and so on until the next measure.
There is a rain gauge which count the drops falling in the gauge. The microcontroller must be able to count even when it's in sleep mode.
For this reason, I setup an external interrupt (on A4) to wake up the microcontroller. The ISR function will incremen a variable. That variable will be use to know the number of drops within 1 hour.
The bunket of the rain gauge is LOW because of a pull down resistance. When the bunket move to the other side, it goes HIGH when is goes close to the magnetix sensor, and then the signal goes LOW when the bunket is in the other side (position).
Then A4 goes HIGH as long as the bunket is close to the magnetic sensor of the rain gauage.
Then, each time A4 is HIGH, the variable increment.
My system work very fine with RISING or CHANGE or FALLING but not with HIGH because the HIGH ststus can be HIGH fore some millis second. The the ISR is called 2-3 time.Then my variable is not incrementing of 1, but 3 or 4.
Regarding your topics, I have not understand if that solution allow RTCZero to wake up with RISING mode, instead of HIGH or LOW? That would be great but I did not understand how I could modify my code.
I also would like to try this solution but as it's not clear for me, I do not know how I can modify my code.
I configured my RTCZero library as the following:
const unsigned TX_INTERVAL = 60; // 1mn
const int pin_arrosage = A4;
#include <RTCZero.h>
/* Create an rtc object */
RTCZero sleep;
const byte alarmSeconds = 10;
const byte alarmMinutes = 0;
const byte alarmHours = 0;
void setup(){
sw.pinMode(wakeup_led, OUTPUT);
sw.digitalWrite(wakeup_led,HIGH);
pinMode(pin_arrosage, INPUT_PULLUP);
//digitalWrite(pin_arrosage, LOW);
//attachInterrupt(digitalPinToInterrupt(pin_arrosage), triggeredDropArrosage, CHANGE);
attachInterrupt(digitalPinToInterrupt(pin_arrosage), triggeredDropArrosage, HIGH);
sleep.begin();
delay(100);
rtczero_resetAlarm()
void loop(){
// Take the measures
// measures();
// When the measures , it goes to sleep mode for 1mn (for the test, it sleep 1mn, but it will sleep for 59mn.)
for (int i=0; i<int(TX_INTERVAL/10); i++) {
sw.digitalWrite(wakeup_led,LOW);
rtczero_resetAlarm();
sleep.standbyMode(); // Sleep until next alarm match
delay(100);
void rtczero_resetAlarm(){
//https://github.com/ProjectsByJRP/M0_Sleep_Wake_on_RTC_int/blob/master/Sleep_wake_on_RTC_alarm.ino
// Variable to set a reference in the time.
byte seconds = 0;
byte minutes = 0;
byte hours = 0;
byte day = 1;
byte month = 1;
byte year = 1;
// Set time reference
sleep.setTime(hours, minutes, seconds);
sleep.setDate(day, month, year);
// set alarm (wake up RTCZero)
sleep.setAlarmTime(alarmHours, alarmMinutes, alarmSeconds); // By default we set at 10 sec, 0 mn, 0 hours
sleep.enableAlarm(sleep.MATCH_HHMMSS);
void triggeredDropArrosage()
// Wait until pin_arrosage is LOW
do{
}while(digitalRead(pin_arrosage)==HIGH);
vcountDrops=vcountDrops+1;
led_state = !led_state;
I am really confuse with this kind of code
EIC->CONFIG[1].bit.FILTEN1 = 1; // D3=eic9
EIC->WAKEUP.vec.WAKEUPEN = (1<<9);
GCLK->CLKCTRL.reg = uint16_t(
GCLK_CLKCTRL_CLKEN |
GCLK_CLKCTRL_GEN_GCLK2 |
GCLK_CLKCTRL_ID( GCLK_CLKCTRL_ID_EIC_Val )
while (GCLK->STATUS.bit.SYNCBUSY) {}
because I absolutly do not understand it. As I underatnd, the first two line,change the behaviour of RTCZero?
Then how can I modify my code, to have my board sleep 10 second, flashing a led, sleeping 1o sec,flashing a led, until next the measures, and when it raining, it count the drop at any time, even during the sleep mode.
Many thank for your help
