I have a AT45DB011D 1Mb flash storage IC I'd like to use with Arduino applications. I have tried to get it to work with several libraries without success. Is there anyone that has successfully used Dataflash chips with arduino that could assist me with using a library for the AT45DB011D?
Most recently I tried the arduino-dataflash library: GitHub - BlockoS/arduino-dataflash: Support for Atmel Dataflash for the Arduino. The available examples haven't worked correctly so I tried to make my own.
Below is my test sketch and the output I see on the Serial Monitor, the returned data values are not as expected. Any help to get my AT45DB011D working would be appreciated.
Sketch:
// arduino-dataflash example
#include <SPI.h>
#include "DataFlash.h"
DataFlash dataflash;
uint8_t page; // dataflah page #.
uint8_t data; // value stored in dataflash.
int i, j; // indices for retrieving data values.
uint8_t status;
DataFlash::ID id;
SPI.begin();
dataflash.setup(10, 6, 7);
delay(10);
dataflash.begin();
status = dataflash.status();
dataflash.readID(id);
Serial.print("Status register :");
Serial.print(status, BIN);
Serial.print('\n');
/* Display manufacturer and device ID */
Serial.print("Manufacturer ID :\n");
Serial.print(id.manufacturer, HEX);
Serial.print('\n');
Serial.print("Device ID (part 1) :\n");
Serial.print(id.device[0], HEX);
Serial.print('\n');
Serial.print("Device ID (part 2) :\n");
Serial.print(id.device[1], HEX);
Serial.print('\n');
Serial.print("Extended Device Information String Length :\n");
Serial.print(id.extendedInfoLength, HEX);
Serial.print('\n');
dataflash.bufferWrite(1, 0);
for (data = 0; data < 5; data++) // send data to buffer:
SPI.transfer(100); // send the number "100".
Serial.print("transfer to buffer, data = ");
Serial.println(data);
Serial.print("transfer buffer to flash, page = ");
Serial.println(page);
dataflash.bufferToPage(1, page); // transfer buffer to dataflash page.
page++;
if (page > 4) // after writing to 5 pages read back the data from flash:
for (i = 0; i < 5; i++)
dataflash.pageRead(i, 0);
Serial.print("page read = ");
Serial.println(i);
for (j = 0; j < 10; j++)
data = SPI.transfer(0xff);
Serial.print("data address = ");
Serial.print("\t");
Serial.print(j);
Serial.print("\t");
Serial.print("data value read = ");
Serial.print("\t");
page = 0;
Output:
Status register :10001101
Manufacturer ID :
1F
22
0
0
transfer to buffer, data = 0
transfer to buffer, data = 1
transfer to buffer, data = 2
transfer to buffer, data = 3
transfer to buffer, data = 4
transfer buffer to flash, page = 0
transfer buffer to flash, page = 1
transfer buffer to flash, page = 2
transfer buffer to flash, page = 3
transfer buffer to flash, page = 4
page read = 0
data address = 0 data value read = 200
data address = 1 data value read = 253
data address = 2 data value read = 235
data address = 3 data value read = 255
data address = 4 data value read = 188
data address = 5 data value read = 115
data address = 6 data value read = 125
data address = 7 data value read = 167
data address = 8 data value read = 231
data address = 9 data value read = 247
page read = 1
data address = 0 data value read = 255
data address = 1 data value read = 255
data address = 2 data value read = 255
data address = 4 data value read = 255
data address = 5 data value read = 255
data address = 6 data value read = 255
data address = 7 data value read = 255
data address = 8 data value read = 255
data address = 9 data value read = 255
page read = 2
page read = 3
page read = 4
