Hi guys,
I'm using the instructions found here to program an ATTINY45 using the Arduino as an ISP:
http://hlt.media.mit.edu/?p=1695
I'm using Arduino 1.0, a MEGA2560 with ARDUINOISP installed, and the ATTiny core found here: Google Code Archive - Long-term storage for Google Code Project Hosting..
Here is a picture of my setup:
Ok, so I modified the Blink sketch to use pin 0 as in the instructions, selected the output board type, and hit "Upload". Here is what happens (I've enabled verbose output in the preferences so I can see exactly what AVRDude is complaining about:)
Binary sketch size: 714 bytes (of a 4096 byte maximum)
/home/rowan/Bins/arduino/hardware/tools/avrdude -C/home/rowan/Bins/arduino/hardware/tools/avrdude.conf -v -v -v -v -pattiny45 -cstk500v1 -P/dev/ttyACM0 -b19200 -Uflash:w:/tmp/build8474854941817919548.tmp/Blink_Tiny.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 9 2011 at 16:00:41
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/home/rowan/Bins/arduino/hardware/tools/avrdude.conf"
User configuration file is "/home/rowan/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATtiny45
Chip Erase delay : 4500 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 256 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 4096 64 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [14] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] @ [40] . [01] . [00] . [00] . [00] . [10] . [00] [20]
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny45
avrdude: Send: P [50] [20]
avrdude: ser_recv(): programmer is not responding
Not sure what's wrong. It definitely seems to be communicating with the firmware, and it even seems to be sending stuff to the chip, but it just messes up halfway through.
Some help would be appreciated.
Cheers,
R
