Topic: 7 hours of work down drain! Bout to give up on ardiunos.. (Read 1 time) previous topic - next topic
ChrisTenone
Good luck on your interview! Getting the job should lower the anxiety level considerably.
Then you can spend your paycheck on more Arduino stuff!
What, I need to say something else too?
GoForSmoke
Nano #3 for some reason isn't resistant to shorting the Grd and VIN pins...
Okay, so this is a joke.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
Qdeathstar
If you shorted the vin and ground pins would that actually damage the device? Current wouldn't be flowing through the device at that point.....
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
TomGeorge
Hi, if there are no series components, then no, there would be no damage.
BUT
If you are supplying power through the DC socket.
There is a series component, the PCB tracks, depending on the power source you could blowout any thin tracks.
Especially if you are using a rechargeable power source and no current limit.
Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
GoForSmoke
There's a fuse on the USB connect. It might be thermal reset.
Boardburner2
You need one of these;
Tom... :)
Annoying thing with those is when you plug in the circuit or wires you cannot read the legend.
I made a custom one which is much wider with easy to read legend.
mattlogue
Yeah. Once a paycheck it's... soldering iron.. LOL, you should see my current... um, the screw terminals... love how they open 40% and close down to 25%, shoot, they work... more nanos, with headers, header leads, breadboards, more passive electronics,
Just because I live in the states don't mean I care
ChrisTenone
Wait 'til you start holding stuff together with double sided tape!
