Hello,
I am having trouble using curl with https. When I use http://www.google.com it works great, but with https://www.google.com it doesn't work. I just updated to 1.5.3.
Here is my example code:
Running process using Process class.
This sketch demonstrate how to run linux processes
using an Arduino Yún.
created 5 Jun 2013
by Cristian Maglie
This example code is in the public domain.
#include <Process.h>
// Initialize Bridge
Bridge.begin();
// Initialize Serial
// Wait until a Serial Monitor is connected.
while (!Serial);
// run various example processes
runCurl();
Serial.println("Looping!");
runCurl();
void runCurl() {
// Launch "curl" command and get Arduino ascii art logo from the network
// curl is command line program for transferring data using different internet protocols
Process p; // Create a process and call it "p"
p.begin("curl"); // Process that launch the "curl" command
p.addParameter("https://www.google.com"); // Add the URL parameter to "curl"
p.run(); // Run the process and wait for its termination
// Print arduino logo over the Serial
// A process output can be read with the stream methods
while (p.available()>0) {
char c = p.read();
Serial.print(c);
// Ensure the last bit of data is sent.
Serial.flush();
Thanks in advance.
Regards,
Daniel
drojasug:
Hello,
I don't understand this, both links are the same.
Anyway, what do you want to retrieve from google.com? I don't see much ascii content in the home page.
Tool Documentation:
http://curl.haxx.se/docs/tooldocs.html
Man page:
http://curl.haxx.se/docs/manpage.html
You likely have an issue with your certificate. You can tell CURL to ignore that and
to get the data anyway. I don't remember how to do that.
Jesse
curl -h |grep certs
-k, --insecureAllow connections to SSL sites without certs (H)
p.begin("curl");// Process that launch the "curl" command
p.addParameter("-k"); // Add the URL parameter to "curl"
p.run();// Run the process and wait for its termination
http://www.ibuyopenwrt.com/index.php/2-uncategorised/218-console-version-of-yun-process-client
Plan B: install ca certificate for system wide fix. (curl, wget ...)
wget -O ca-certificates_20140325_ar71xx.ipk https://www.dropbox.com/s/rmvkunea1ifa9zn/ca-certificates_20140325_ar71xx.ipk?dl=0 --no-check-certificate
opkg update
opkg install openssl-util
opkg install ca-certificates_20140325_ar71xx.ipk
http://forum.arduino.cc/index.php?topic=273342.msg1930879#msg1930879
mart256:
The links are different, one is using regular http protocol, and one is using secure https. He's having trouble with the secure connection. I assume the URLs are a simplified example to explain the point, and not the final URL that he is trying to access.
The CA is update very often.
I compile latest up today ca-certificates
wget -O ca-certificates_20150426_ar71xx.ipk https://www.dropbox.com/s/oqm1q833ell0wq3/ca-certificates_20150426_ar71xx.ipk?dl=0 --no-check-certificate
opkg update
opkg install ca-certificates_20150426_ar71xx.ipk
ShapeShifter:
Didn't know that difference. Thanks for the acalaration.
