Hey Guys,
I'm attempting to take bytes that contain time and date and make them into a string for the purpose of naming a file on an openlog. My clock produces: month, dayOfMonth, hour, and minute in bytes. I tried char() but had no joy. Lots of ascii spaces.
Suppose it was October 28th at 14:12. I would want my file name to be "10281412." Problem is, I have no idea how to make:
byte minute 12;
turn into:
char minute[2] = "12";
I've seen in some examples people using springf(). I liked the one instance where I saw it, but I can't figure out how it works exactly.
Any guidance much appreciated!
Hunter
I included some (marginal) code below to help you understand what I'm trying to do.
#include "string.h"
// bytes each of the components
byte minute;
byte hour;
byte dayOfMonth;
byte month;
// strings for each of the four components
char Cmonth[2];
char CdayOfmonth[2];
char Chour[2];
char Cminute[2];
char TimeDate[8]; // will contain all of the four components in a string
// Data as it arrives off the clock
minute = 12;
hour = 14;
dayOfMonth = 28;
month = 10;
//**** need something here that will turn bytes into integers
// I have no idea if this is legal, or how I'd go about putting all of my CHAR's into one long string.
TimeDate[8] = {month, dayOfMonth, hour, minute};
Serial.print(TimeDate);
//**** I want to see: "10281412"; That's month dayOfMonth hour minute.
Moderator edit: </mark> <mark>[code]</mark> <mark>
You need space for a trailing 0 as end of string indicator, so TimeDate has to be at least 9 chars wide .
You don't need string.h
If it's just to create a file name, you can do that in one shot: sprintf (TimeDate, "%02u%02u%02u%02u.log",month,dayOfMonth,hour,minute); should produce "10281412.log"
Your explanation of sprintf combined with what I saw in an openlog example were the magic trick. The line that ultimately worked was:
sprintf(buff, "new L%02d%02d%02d.txt\r", month, dayOfMonth, fileNumber);
I didn't mention any of it in the first post, but I needed "new" to initiate the new file. I replaced hour and minute with fileNumber to keep the name under the size 8.3 limit. Then I added \r, and I have no idea what it means or why it's necessary, but it works.
Thanks a ton for your good explanation and quick response.
What, exactly, are you doing with the resulting buffer? The SD library does not expect that "new " in there, nor will it operate correctly with it there.
The \r is a new line, often used to indicate the end of a command, which implies that the array you are populating defines some kind of command.
Serial.print(buff); //\r in string + regular print works with older v2.5 Openlogs
sprintf(buff, "append L%02d%02d%02d.txt\r", month, dayOfMonth, fileNumber);
Serial.print(buff);
I wish I could get Serial.read to work so I could see that the OpenLog is alive before I start sending data (as Nate does in the example). It stopped working last night (hence no while loops). I don't know what failed, I suspect hardware.
the (now commented-out) version with sprintf() uses 3290 bytes of code space. The alternative code which uses a family of str*() calls, and looks larger, uses only 2056 bytes. You can see a number of str*() and mem*() functions here:
and they are worth adding to your programming toolkit.
I have a similar issue. I was writing some code in the online IDE and it compiled fine. When I downloaded it and tried to compile it with the Windows version of the IDE it throws an error that it can't convert byte to char. What I was doing is basically trying to copy byte array to char array. Those bytes are actually ASCII characters so I wouldn't need any conversion.
It looks something like that:
void CopyCharArrayPart(char CharArrayIn[], char CharArrayOut[], unsigned int Start, unsigned int Length)
unsigned int cnt; // Counter variable
for (cnt = 0; cnt <= Length; ++cnt)
CharArrayOut[cnt] = CharArrayIn[cnt + Start];
byte RDBuf[18];
char Name[4];
Serial.readBytes(RDBuf,18);
CopyCharArrayPart(RDBuf,Name,6,4);
If I try to cast it like this:
CopyCharArrayPart((char)RDBuf,Name,6,4);
It tells me that it loses precision. I guess it's trying to put a termination character at the end, which I don't need.
Any idea why this compiles online and not on Windows and how to fix it without adding a tone of code? I use IDE 1.6.6.
No, it is because a char on some systems, like the Arduino is a signed type, with a range of values from -128 to 127. Byte is an unsigned type, with a range of 0 to 255. Trying to store a value like 200, which is perfectly valid in a byte, in a char could result in a loss of precision.
Create another function that takes a byte array as the first argument.
Didn't have that kind of char problem with C compilers for PIC so it was unexpected. I just changed the input of the function to byte array since that what I will use it for and save memory. Thanks for the info.
