If the manufacturer says its compatible, then its probably is. It should work with your uno. You should still call and confirm this with rhydo. They have good presales support.
The only time you can bump into a problem is when you use one of the larger arduinos like the Mega which have analog and SPI on different pins thus making them non compatible.
