chipKIT Max32 [Arduino compatible PIC board]
Link:CHIPKIT-MAX32
No doubt about it, there are a lot of horses under the hood of that controller. And it claims to be "Arduino compatible".
I'll be getting one as soon as I come up with a project that actually needs that much power. (And I can convince the wife that I truly need yet another electronic 'gizmo'.)
I can wrap my head around the physical aspects of this board, but what has me a bit perplexed are the IDE choices that the "Arduino Compatible" tag brings with it.
If you can program it using the Arduino IDE, wouldn't that limit you to the 8-bit environment that Arduino was built around? (in regards to added cpu cycles for complex math,added overhead for floating point, etc)
Wouldn't it just be better to use MPLAB from the start? Or am I totally off base?
meh... disregard my Q above.
I just noticed the following:
Program using a [b]modified[/b] version of the Arduino IDE, available as a free download for PC, Mac OS, and Linux.
Heh! That wasn't there before, and they got some beating over on hack-a-day.
Good for them for updating it and making things clearer!
Hmmm.... I just heard about this from another source. But I can see other have gotten here before me.
Still... thinking about getting it. Do not have a project that needs it as such .. yet ...
Well, in the beginning one can just try the IDE, to see how differnet the structure is.
Be careful how much you read into this. It claims to be compatible with the Arduino hardware.
The Max32 is the same form factor as the Arduino Mega board and is compatible with standard Arduino shields as well as larger shields for use with the Mega boards.
So in practice you will be using its modified 'Arduino' IDE to generate code for a PIC processor. You will have a familiar interface and you can reuse your old Arduino shields.
Don
Of course it uses another IDE, it must have a compiler for a MIPS processor and not for a AVR Atmega processor, but it as the same libs and if you feed it arduino code it will eat it and spit a nice working hex.
Worth checking when the software is actual avalible to look at (5/21/?? stated availability). It's must be flattering for the Arduino founders to see so many other microcontroller companies trying to emulate the look and feel of the Arduino platform. A real complement I would think.
Lefty
I ordered one of each model. I've a couple of FPGA development boards from Digilent and they produce good stuff, they said that will start shipping on the 21st.
There is some software available at the Microchip site but I didn't look at it yet.
The PIC32MX is a very nice microcontroller, I do a lot of development with it, not sure if will make sense to even use the "Arduino like" IDE, MPLAB IDE from Microchip is a fairly good IDE and you can download the C32 compiler which after the evaluation period has some limitations. Not sure yet how good the compiler for these boards will look like, also for some applications it may be worth to just get a PIC programmer and bypass the bootloader.
Arduino is becoming a popular quasy-brand, more now that Google is making a lot of noise with the ADK, these are obviously not "Arduino" boards, they share the same pcb layout and pin-out of the regular Arduino boards. It claim to be open software/hardware, you can download the zip with the eagle layout for both boards (4-layer).
I'm thinking about putting together sort of a Ethernet shield based on the Microchip ENC424J600 controller, drop some external FLASH so the Microchip TCP/IP stack can run on these boards.
Cheers
Never mind, the links at the Microchip site for the software download still point back to the Digilent product page.
Bummer
The software is now ready to download
https://github.com/chipKIT32/chipKIT32-MAX/downloads
All 3 OS versions are ready to go (Mac, Windows, Linux)
As far as how it works, the core files and library files of course have been re-written to use pic32 hardware instead of avr hardware
The ide has been modified to have a platforms.txt in addition to the boards.txt. This allows multiple compilers to be used. The design idea is that any gcc compiler can now be made to work just by adding a text file (platforms.txt) Everything about the compiler is driven by that file.
The biggest difference in what we did compared to what maple did, is now you can select back and forth between AVR and PIC32 without changing programs. Just go up the boards menu and select a different board. Mega2560, Arduino-UNO, chipKit-MAX32 or chipKit-UNO. and click download. Thats all there is to it.
We are calling it MPIDE for Multi-Platform IDE
For anyone that has looked inside of the java ide code, the section that drives the compiler has been COMPLETELY re-written. This was a MAJOR undertaking.
I am at Maker fair this weekend if anyone wants to stop by and see it and learn more how it works
Mark
lead programmer in the pic32 chipkit/Arduino project
For anyone unable to download the Windows version from;
Someone just posted an alternate download file which appears to be working.
Cheers.
Peter Anderson
Congrats. Cool.
Um, is Microchip driving this? DigilentInc? Just another volunteer open-source project?
I guess this is the most "politically interesting" development in Arduino-land since Freeduino.
(well, probably MORE interesting than Freeduino, and less political, but it will be interesting to see how things work out.)
I am at Maker fair this weekend if anyone wants to stop by...
Which booth/vendor would that be? Microchip?
How close is this to being able to use non-gcc compilers? Seems to me that the ability to use your favorite commercial AVR compiler (perhaps with more complete libraries) has always been "of interest"...
..anybody tried to run the mpide under win xp sp3?..
I had to download via git, every time I tried to download the Windows version I've got access denied.
The new platforms.txt should work with any command line compiler. The whole idea is to be able to put in any compiler you want. We have not tested with non-gcc compilers but it should work. If you try it out, let me know. All the source is on github and we would gladly help make it work with other compilers.
Mark
Where can one find info on developing with MpLAb C32. Is a plug in required for C32?
In the Microchip forums of course!
Couldn't find one post in the MicroChip forums. I guess if using C32 then any code will have to be written in C as opposed the Arduino C++
Yes. It was C32 you asked about, and mplab. The existence of Chipkit and MPIDE in no way means that Microchip has decided to throw away their other development tools and make everything arduino C++ compatible! The chipkit boards are primarily being supported by chipkit.org, digilent, FUBAR Labs, and (lastly) Microchip's educational division. If you want to use C32 and MPLAB with the Chipkit boards, you're probably expected to populate the ICSP connector and treat the board as a general purpose generic PIC32 development board (which it is, in the same way that an Arduino can be used with AVRStudio as a general purpose AVR board.)
Late 2012 update. chipKIT Max32 v. Arduino Mega 2560. chipKIT is Not really a drop in board. Their company(s) are not aggressive in converting or making a compatible product with compatible libraries or conversions for popular Arduino uses.
I tried a simple application - I took a common RepRap RAMPS 1.4 board for a 3D printer and tried to compile a very popular Arduino firmware - Marlin, on the chipKIT using the supplied MPIDE. It gave errors to libraries which it could not locate. I asked MicroChip and they told me the chipKIT is not avr compatible. Hmmm, I thought they were marketing it from last year as Arduino (avr) compatible. They directly told me that Arduino is 8bit and they were 32bit and not compatible. They went on to tell me pins don't correspond, coding is not the same, voltages are different, etc.... I was left dumb looking at all the advertisement sources - even the packaging - stating 'Arduino Compatible'
So, who is telling the truth? I don't know and do not have the time or care to figure it out or to do the heavy program lifting to re-generate or convert libraries to make a non-compatible environment compatible when I can create awesome things with the Arduino - NOW!
I think they are greedy for market share, money and too lazy. They want YOU to create a market for them, a lazy company, that touts that they can play in the game then tell you all the reasons why they aren't.
MicroChip support told me I'd have to do the conversions and code writing to attach to the RAMPS. I'll just use my Mega 2560.
Thus, if you want to use chipKIT Max32 to be compatible with the Arduino - you can plug your chipKIT board to your Arduino shield and it had better be a 3.3V or else. I was told that I'd have to program pins conversions, hardware libraries etc.... So, as for me, a user, I don't see compatible. If I only had to plug something to an Arduino shield and had to do all the programming I might as well make my own board for my chosen experimental mcu too.....
Hope this saves you some time and answers some questions....
